Slant Six Forum https://www.slantsix.org/forum/ |
Alignment specs https://www.slantsix.org/forum/viewtopic.php?f=13&t=61815 |
Author: | Lobster1 [ Mon Jan 08, 2018 8:05 pm ] |
Post subject: | Alignment specs |
I finally gave the 62 Lancer the Firm Feel treatment; 1.06 bars, boxed LCA's, tubular uppers, Bilstein's, swaybar, sub frames and heavy duty strut rods... Now I need it aligned. What are recommended numbers for road racing and maybe occasional street use as well? 170/4 speed with 225 50 15's. Cheers, Barnaby |
Author: | Dart270 [ Tue Jan 09, 2018 9:10 am ] |
Post subject: | Re: Alignment specs |
Hi Barnaby, Sounds dangerous! Bet you're excited. Race tires or street tires, or what kind/brand/model? For track and street, I would shoot for 1 deg negative camber, +4 to +6 caster and 0 deg toe or a bit (up to 0.1 deg or so) toe in. Some folks will recommend very high caster numbers (+6 to 10 deg), but I do not believe those work well on an A-body tbar suspension. Ehrenberg agrees with me. You could go maybe 1.5-2 deg negative camber, if you are using racing tires, but you will see more wear on the street. Cheers mate, Lou |
Author: | Lobster1 [ Tue Jan 09, 2018 9:31 am ] |
Thanks Lou! I have Proxes RR's, so I will need a second set for the street. I am not concerned about excessive wear, I want this car to handle as well as possible. Cheers, Barnaby |
Author: | Dart270 [ Tue Jan 09, 2018 11:53 am ] |
OK, sounds good. I would go 1.5 deg neg camber then. Let me know what you are thinking for track events or AutoXes. I need to plan a trip out to Seattle to drive and/or pick up my 64 Dart. It is ready to rumble and I miss it. Lou |
Author: | tophat [ Tue Jan 09, 2018 5:32 pm ] |
Lobster1 wrote: Thanks Lou! I have Proxes RR's, so I will need a second set for the street. I am not concerned about excessive wear, I want this car to handle as well as possible. Cheers, Barnaby Sounds like this is primarily a race car. To be as fast as possible, you need to set it up for the track you are running. More tracks, means more setups in the notebook. Street, is just another setup. The numbers you were given are a great starting place for the street. For the track, take tire temps after a few laps and adjust your camber accordingly. You want the temp even as possible across the tread. Be sure to reset toe after each camber adjustment. |
Author: | Lobster1 [ Wed Jan 10, 2018 8:28 am ] |
Thanks Lou and Tophat, I probably will only drive the car on track days initially for debugging and cost savings. PIR is my local track and I doubt I would take the car to California of Washington. Cheers, B |
Author: | Dart270 [ Wed Jan 10, 2018 8:40 am ] |
Would love to run a track day at PIR with you! Lou |
Author: | Lobster1 [ Wed Jan 10, 2018 2:58 pm ] |
Lou, that would be so cool! And possibly I could drive one of my cars back east and hit one of your tracks... I will most likely work sales on the east coast, DC, Virginia, NC, SC and Georgia. |
Author: | jcc [ Fri Jan 19, 2018 3:24 pm ] |
I agree with the 1-2 Neg camber suggestions, big general turn in handling improvement in any application. What did you do with brake upgrades to have the same relative performance improvement capability? |
Author: | Lobster1 [ Fri Jan 19, 2018 4:14 pm ] |
See my current thread Best Master Cylinder. They are not yet where they should be. Hopefully in a few weeks I can share my resolution. B |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
