Slant Six Forum https://www.slantsix.org/forum/ |
Borgeson steering box https://www.slantsix.org/forum/viewtopic.php?f=13&t=67568 |
Author: | wjajr [ Thu Dec 28, 2023 5:52 am ] |
Post subject: | Borgeson steering box |
I finally got to install a Borgeson box and GM stile Saginaw pump on the 67 Dart. I feels much tighter during the 1/4 mi short test drive last night. The project went fairly well, except pressure hose's bend needed to be tweaked a bit to attache to its port on the gear. I ordered the pump & pulley, power steering adapter hoses, PS gear, BAC Steering coupler, and slant six pump bracket. The coupler looks like an elongated factory coupler, and contains the same guts as a factory coupler. The BAC coupler eliminated the need to cut the steering column and use of a Borgeson "U" Joint. I'll know more how this new gear performs once spring has sprung and the salt has washed off of the roads. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
