It is currently Fri Jul 17, 2026 1:24 am
 Post subject: need help
PostPosted: Wed Apr 27, 2011 5:49 pm
Does anybody no whatever size crank damper bolt is need on a 73 /6
Neither of the two motors that I got at home have them :(
PostPosted: Wed Apr 27, 2011 9:59 pm
The bolt's not "missing". Most slant-6 engines came without them. The damper is an interference (press-on) fit onto the crank snout. If you want to install a bolt for some reason (or you need one to install the damper), it's a ¾"-16 × 2½" bolt with appropriate washer.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 5 guests
