http://www.slantsix.org/forum/
Separate the Twins? - Twins #2, Comments
http://www.slantsix.org/forum/viewtopic.php?f=19&t=27397
Page 1 of 7
Author:  Doctor Dodge [ Sun Feb 24, 2008 9:36 am ]
Post subject:  Separate the Twins? - Twins #2, Comments
I am finally getting somewhere with the second "twin" engine build-up, that we started covering in this thread:
http://www.slantsix.org/forum/viewtopic.php?t=26159
When we first started that thread, we though the Guzzi engine would go pretty fast and that we would quickly shift over to "Raquel". Things did not go as planned and the Twins thread is now 6 pages of mostly Guzzi build info.
So here is the question: should we split Raquel's engine assembly / engine build into a new thread or keep posting it to the original "twins" message thread?
What is easier for everyone to follow?
Author:  sandy in BC [ Sun Feb 24, 2008 9:41 am ]
Separate them at birth and follow for 30 years.....
Then we can figure environment versus genetics....
Start a new thread and lock it.
Add another thread for comments and questions....that get answered in the locked thread.....or mebbe that comment thread is this thread......
Author:  Charrlie_S [ Sun Feb 24, 2008 10:05 am ]
Separate.
Author:  SlantSixDan [ Sun Feb 24, 2008 10:08 am ]
I vote with Sandy.
Author:  Aggressive Ted [ Sun Feb 24, 2008 10:23 am ]
Separate threads
Author:  dakight [ Sun Feb 24, 2008 11:49 am ]
Definitely seperate.
Author:  Kidd [ Sun Feb 24, 2008 2:18 pm ]
I say seperate.
Andrew
Author:  argentina-slantsixer [ Sun Feb 24, 2008 4:46 pm ]
I'm a "separationist" (if you will) too! :wink:
Author:  emsvitil [ Sun Feb 24, 2008 4:48 pm ]
Seperate them, but put a link in the first post of each pointing to the other one...............
Author:  69a100 [ Mon Feb 25, 2008 8:32 am ]
separate at birth!
Author:  CARS [ Mon Feb 25, 2008 8:46 am ]
I'm with Sandy too. It seems like things really get off track when the tread isn't locked.
Author:  Doc [ Mon Feb 25, 2008 1:46 pm ]
So.... it looks like a "seperation operation" is called for.
I like the idea of a locked thread on the new post, seeing that this engine build will have to be "fast tracked" if I am going to get the motor built, dropped into the racecar and debugged in time for the Las Vegas race.
I can do a good, basic "step-by-step" SL6 engine assembly post that should help anyone assemble a SL6, stock or not.
Time to go "scrub".... :wink:
Author:  Evilsizer [ Mon Feb 25, 2008 1:55 pm ]
thanks for doing that Doc!!
Author:  Doc [ Mon Feb 25, 2008 5:54 pm ]
Post subject:  This is now the Comments Thread for Raquel...
OK, I started and locked a "Twins #2" message thread and added the first installment.
Here is the link to that post.
I will continue checking here for questions & comments about that engine.
Author:  Bren67Cuda904 [ Mon Feb 25, 2008 6:09 pm ]
Just incase you wanted or didn't know. I used a BH block (Eileen) and bored it big time. I personaly think I got lucky and found a perfect cast block though. 8)
http://tinyurl.com/ywj2e3
Page 1 of 7 All times are UTC-07:00
