It is currently Thu Jun 04, 2020 11:50 pm
PostPosted: Mon Jan 20, 2020 1:47 pm
Car Model*:
Can a wiseco piston be hung on a stock type 225 Rod?
Greg Ondayko
PostPosted: Mon Jan 20, 2020 3:21 pm
Car Model*: 65 Valiant 2Dr Post
I wouldn't know why not??
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
PostPosted: Mon Jan 20, 2020 3:43 pm
Car Model*:
Well the stock rods use press fit pins and the wisecos use floating pins.
Would that combo use the wiseco pins?
Do the wiseco pins get pressed into the stock rods?
Greg Ondayko
PostPosted: Mon Jan 20, 2020 4:17 pm
Car Model*:
Stock rods can be "floated". But using the Wiseco pistons on stock 225 rods, will have the piston way down in the bore, much further then the stock piston.
66 Valiant Signet 225 nitrous
PostPosted: Mon Jan 20, 2020 5:43 pm
Car Model*:
Thanks charrlie.
To do that does the stock Rod require machining?
I will have to measure / compare compression heights.
Greg Ondayko
PostPosted: Mon Jan 20, 2020 7:00 pm
Car Model*: Many Darts and a Dacuda
The right way to float the piston pin in the rod is to machine the small end of the con rod to accept a pin bushing, press-in the bushing and hone it to finish size.
Another way is to simply hone the rod's small end to the correct clearance dimension and run "steel-on-steel". (a hardened steel pin on a forged steel con rod)
In ether case, an oil hole should be added at the top of the rod, to allow oil to enter the pin area.
PostPosted: Tue Jan 21, 2020 2:46 am
Car Model*:
Nice discussion. Mike J floated steel on steel way back when. Dennis might have a motor like that?
Why use the short piston on the short rod? Stroker crank?
"You mean you still have a Slant 6 in that thing?"
PostPosted: Tue Jan 21, 2020 8:50 am
Car Model*:
No I wasnt thinking stroker crank, yet...but i have some very small cc heads that I wanted to use...
Just thinking.
Greg Ondayko
PostPosted: Tue Jan 21, 2020 9:36 am
The 1.6 compression height piston may be a little too short. (appx a -.300 D.H.)
This would get a static compression around 7.7 with a 35 cc head chamber.
Maybe look at the specs for the export SL6 7 to 1 CR piston, that may-be a better option.
PostPosted: Tue Jan 21, 2020 11:30 am
Car Model*:
I have run floated stock rods before with no issues. Oil hole in the top.
Current race motor has 6.7 inch rods and Wiseco pistons..plus a turbo.
PostPosted: Tue Jan 21, 2020 12:20 pm
Car Model*:
As stated, floating steel rods, without bushings is not a problem. Having the oil hole is critical. Over the years I have done many steel on steel floating. On many different engines. On many stock rods there is not enough "meat" on the small end to add a bushing, safely.
PostPosted: Tue Jan 21, 2020 12:40 pm
Car Model*:
What is the the compression height of std / stock 225 /198/ 170 pistons?
Greg Ondayko
PostPosted: Tue Jan 21, 2020 12:51 pm
Car Model*:
1.74" is stock. 2.2L pistons are around 1.59" and Wisecos are 1.60 or 1.61". Last two are from memory, but I am pretty sure.
What is your head volume? Smallest I have made/used (milling and "proud" valve heads) was 30 cc. Not hard to make 33-36 cc's.
PostPosted: Tue Jan 21, 2020 6:45 pm
Car Model*:
Well i am just kicking some Ideas around.
I like the lighter rods and pistons.
However for the heads I have available (done correctly with massive valvrs) they are probably milled too much to be practical in a 198/225 block with the 225 crank and long rods. I need to do some calculations for sure. Just trying not to build a new head.
I could always go with hyperteutic's as well.
A 2.2 flat top piston 1.594 comp. Height on molnar rods might work as well. My calc's on a stock 225 crank /block put the piston about ~0.060" in the hole with a 45cc head might be streetable for the green dart!
Probably available in 88, 88.5, 89mm ø!
Greg Ondayko
PostPosted: Wed Jan 22, 2020 2:52 am
The MLS head gaskets that Ryan had made were available in any thickness you want, That would help lower compression on a head that has been milled a lot or too much..
