Slant Six Forum https://www.slantsix.org/forum/ |
A904 Transmission Temperature Sender https://www.slantsix.org/forum/viewtopic.php?f=20&t=62055 |
Author: | jkotis [ Wed Mar 07, 2018 8:06 pm ] |
Post subject: | A904 Transmission Temperature Sender |
Is there a port on the A904 transmission that can be used to attach a 1/8" NPT temperature sender so I can connect a transmission temperature gauge? Failing that, I have installed a deep transmission oil pan with a drain plug. Would it be advisable to install the sender in the drain hole or should I just use a "T" connection on the "In" line to the radiator cooler? |
Author: | Reed [ Wed Mar 07, 2018 8:13 pm ] |
Post subject: | Re: A904 Transmission Temperature Sender |
I would use the return line from the radiator mounted trans cooler and someting like THIS |
Author: | hank [ Sat Jun 02, 2018 10:52 am ] |
I used a tee fitting comeing out of the trany. And put the sender in the tee to see how hot the trany was getting. Put the line streight through the fitting. Works nicely. |
Author: | slantzilla [ Thu Jun 07, 2018 3:37 pm ] |
Mine has a fitting welded into the pan. If I were putting one in a cooler line, I'd use the line to the cooler. That will tell you what the trans is doing better than the return from the cooler. T in the line will be easiest. |
Author: | tophat [ Thu Jun 07, 2018 6:29 pm ] |
The T line is quick and easy. I use the line going in to the cooler so I know the trans temp. The line coming out of the cooler will only tell you how effective your cooler is. Trans temp shouldn't be a problem unless you tow a heavy load. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
