It is currently Fri Apr 19, 2024 12:49 pm
PostPosted: Tue Sep 03, 2019 6:28 pm
What size o-ring does the shift cable on a 1963 A904 use?
63 Signet / 10 inch front drums / weber 2bbl / HEI / 3.23 rear end
PostPosted: Sat Sep 07, 2019 8:04 am
I cleaned the transmission fluid from the shift cable adjusting wheel area and the cable and tie-wrapped a paper towel around the cable.
A week later, the paper towel is still dry and the adjusting wheel and surrounding area is wet.
It is definitely the o-ring behind the adjusting wheel.
Does anyone know the part number or size o-ring that is used?
PostPosted: Tue Sep 17, 2019 2:59 pm
I don't know the size. I just bought an assortment at the auto parts store and picked one that fit.
Escape Velocity Racing
PostPosted: Sat Dec 07, 2019 11:10 am
I've had to do this a couple of times now. There are a lot of O rings that look like they would fit, only to leak like a sieve when installed.
What I ended up doing was buying a #91 O ring and wallowing out the inside just a bit with a fine sanding disk on a Dremel. Keep the Dremel moving and only take off enough rubber to make it barely small enough to slip it into the bore on the transmission case.
I have done two transmissions this way and both of them are holding so far.
1961, 1962, 1963 and 1965 Valiant 200. The `65 is a `vert.
PostPosted: Tue Jan 21, 2020 10:11 pm
Do you mean a small sanding drum?
PostPosted: Wed Jan 22, 2020 1:37 pm
I do mean a standing drum. Thanks for catching that error.
PostPosted: Sat Jan 25, 2020 8:54 pm
Thanks. I'm going to try that as soon as dry weather returns.
Users browsing this forum: No registered users and 15 guests
