It is currently Thu Mar 28, 2024 1:10 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
 Post subject: Re: Rebuilt transmission
PostPosted: Tue Mar 10, 2020 12:49 pm
That $750 rebuild is going to be much more appropriate. You don't need to be thinking about special stall speeds. Get a stock rebuilt torque converter; that's what's suitable for the kind of car you're building. 3000 RPM is much, much too high; that would be a race car piece, and you'd be pissing away gasoline money every time you drive the car, and heating up the trans fluid to the detriment of everything, and it'd be a poor match for the low-RPM torque motor you'll want in a fun-driving car like you're building. Attached to this post is the factory '69 stall speed chart. Your situation is the 2nd line in the chart: 225 engine and 904 transmission. More/higher is not necessarily better!
And be very picky and specific with the shop about that "mild shift kit". Specify a Transgo TF-SC. You could go one step further to a TF-1, but there wouldn't really be a benefit and you might not like it so much.
There really isn't a whole lot of re-engineering or upgrading needed here; you're starting with a very well engineered transmission.
PostPosted: Tue Mar 10, 2020 8:26 pm
This one
https://www.ebay.com/i/191920797415?chn ... aAhVeEALw_
Thanks for all your help.
PostPosted: Tue Mar 10, 2020 8:58 pm
Yup! That one.
PostPosted: Fri Mar 13, 2020 7:41 pm
Save the money, do like Reed said and also like I do, rebuild your own. I'm about to do just that on the A500(42re) in my daily driver 99 Dakota to fix it's slipping 2nd gear. Just waiting for 1 more part to arrive in the mail before I pull it.
PostPosted: Sat Mar 14, 2020 5:16 pm
Car Model: 1961 Dodge Lancer 770, 1938 Dodge Business Coupe
I would add that care not tearing lip seals and cleanliness are two major reasons for transmission rebuild failures. Patience and cleanliness are all you need for a successful rebuild.
61' Lancer 4 door shaved .200 ported polished,Balanced, Hyper-pak ,Headers,dual 2.5", 4 speed, 3.23 posi 8 3/4",205 70
Users browsing this forum: No registered users and 29 guests
