It is currently Wed Apr 24, 2024 5:07 pm
 Post subject: Rocker Arm Spacers
PostPosted: Sat Mar 23, 2002 1:15 pm
I was wondering if the spacers that go between the rocker arms on the rocker shaft are available new anywhere. My rocker arms are moving for and aft quite a bit with the engine running. Thanks for any help!
Eric W
My Big B
ecwfury@webtv.net
 Post subject: Re: Rocker Arm Spacers
PostPosted: Sun Mar 24, 2002 7:28 pm
(User Above) wrote:
: I was wondering if the spacers that go between
: the rocker arms on the rocker shaft are
: available new anywhere. My rocker arms are
: moving for and aft quite a bit with the
: engine running. Thanks for any help!
: Eric W
Rocker Arm Specialists (RAS) have washer shaped "shims" you can use.
I grab a bunch of the wider center spacers (wrecking yard candy) and I grind them down to fit each position.
Users browsing this forum: No registered users and 19 guests
