It is currently Thu Mar 28, 2024 10:03 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Re: 2X1 intake manifold
PostPosted: Sun Apr 07, 2002 8:12 am
Thought I was doing something new, well different set up anyway. I used the original intake and exhaust manifolds and two Holley single barrels.
http://hometown.aol.com/slantedsix225/carbs_index.html
SlantedSix225@aol.com
PostPosted: Sun Apr 07, 2002 9:55 am
(User Above) wrote:
: Thought I was doing something new, well
: different set up anyway. I used the original
: intake and exhaust manifolds and two Holley
: single barrels.
That *is* different.
Did you make the adaptor and air cleaner "hat"?
I think a small Turbo would be a good next step, that would help the flow though the single opening 1 BBL manifold.
PostPosted: Sun Apr 07, 2002 11:23 am
(User Above) wrote:
: That *is* different.
: Did you make the adaptor and air cleaner
: "hat"?
: I think a small Turbo would be a good next
: step, that would help the flow though the
: single opening 1 BBL manifold.
: DD
Yes I made them. you can see the mocks I used to make the castings on this page on the site I'm working on to show the install in progress. I'm going to put in the IHI turbo off of a Subaru 1.9 L. as soon as I get the rebuild kit I ordered from Turbo City. By the way Doug, those are the carbs I got from you.
http://hometown.aol.com/slantedsix225/enginecompartment.html
