It is currently Wed May 15, 2024 6:59 am
PostPosted: Fri May 30, 2014 8:50 pm
Car Model: 1965 Barracuda 'S' auto
My sensor is about 2 off TDC, is there an offset you can plug into MS to compensate for a stationary sensor (that should have been adjustable but I thought I nailed it) ? I thought I saw something like that in there. Sort of a global timing offset?
I didn' t buy it, I built it.....
PostPosted: Fri May 30, 2014 9:19 pm
Yes - using EDIS there is at least. Called Trigger Offset or Advance Offset. Which tuning software are you using? In Tuner Studio its under tools > Trigger Wizard.
http://www.diyautotune.com/tech_article ... how_to.htm
PostPosted: Sat May 31, 2014 10:45 am
sweet! whats the max value? I know EDIS only does 10 degrees limp home but this allows a few mm wiggle room on mounting a VR pickup or adjusting a slipping trigger wheel.
PostPosted: Mon Jun 02, 2014 9:57 am
If it's within 5 degrees, I wouldn't worry about it too much.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
