Slant Six Forum https://www.slantsix.org/forum/ |
HEI conversion but now hard to start https://www.slantsix.org/forum/viewtopic.php?f=28&t=60759 |
Author: | bbgbouncer [ Thu Feb 09, 2017 10:34 am ] |
Post subject: | HEI conversion but now hard to start |
I have converted my 73 w100 360 to HEI. Once it is running it works. However I have a really hard time getting it to start. the engine only seems to "catch" when I let off the key. Any thoughts? |
Author: | drgonzo [ Thu Feb 09, 2017 10:54 am ] |
Post subject: | |
I would think you are not getting enough power to the ignition. I relayed mine straight from the battery and she starts and runs great. |
Author: | Reed [ Thu Feb 09, 2017 11:11 am ] |
Post subject: | |
Have you tried reversing the leads to the distributor? Did you remember to remove the ballast resistor and put a jumper in its place? |
Author: | bbgbouncer [ Thu Feb 09, 2017 11:43 am ] |
Post subject: | |
I have already reversed the leads it did not help. I will try that again. I will check to see if I have power when the key is moved to start. |
Author: | wjajr [ Thu Feb 09, 2017 11:54 am ] |
Post subject: | |
Mopar stock ignition design has two circuits: "start" that supplies a full 12v to coil when starter is engaged; "Run" circuit is energized when key is in run position and ballast resistor is part of this stepping down 12v to 8v or so a level stock coil can live with. Only one of the two circuits is energized at any given time. If you are not getting light-off during starter engagement, that start circuit is not able to supply voltage to coil for some reason. I think you need to tie the run and start circuits together. |
Author: | bbgbouncer [ Thu Feb 09, 2017 1:23 pm ] |
Post subject: | |
I feel like an idiot. I did not wire the "start" wire to the coil/HEI. I had only run the ignition on wire. hooked up the start wire and it works like magic. |
Author: | Reed [ Thu Feb 09, 2017 1:37 pm ] |
Post subject: | |
Author: | Rick Covalt [ Thu Feb 09, 2017 4:45 pm ] |
Post subject: | |
Quote: I feel like an idiot
I feel like that quite a bit! Welcome to the club, your in good company. Glad it was an easy fix. Rick |
Author: | Reed [ Thu Feb 09, 2017 4:54 pm ] |
Post subject: | |
Rick Covalt wrote: Quote: I feel like an idiot I feel like that quite a bit! Welcome to the club, your in good company. Glad it was an easy fix. Rick Yeah, its a rare day when I don't feel like an idiot! That just means I am always learning new things. |
Author: | SlantGeek [ Fri Mar 24, 2017 7:55 am ] |
Post subject: | |
Reed wrote: Rick Covalt wrote: Quote: I feel like an idiot I feel like that quite a bit! Welcome to the club, your in good company. Glad it was an easy fix. Rick Yeah, its a rare day when I don't feel like an idiot! That just means I am always learning new things. Ha, I'm an ASE certified mechanic (http://www.dulleschryslerdodgejeep.com) and stuff like this happens to me too. It really irritates me when it does but you know Murphy's law. The guys above have nailed the answer. HID bulbs draw a lot of power, especially on startup. If thats starving your ignition, yup...it might not start. Thanks for sharing this with everyone! |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
