It is currently Fri May 24, 2019 11:07 pm
 Post subject: Starter question
PostPosted: Tue May 29, 2018 8:02 pm
3 Deuce Webber
Car Model*:
Doing a trans swap from a 903 3 speed to an 833OD. The 3 speed was set up with a low mount starter and I need to install a high mount starter for the 4 speed. What would be some recommendations for a new starter. I have seen everything from a V6 Dakota to a Hemi mini starter. Any suggestions would be great and the most frugal choice would be best.
Thanks
 Post subject: Re: Starter question
PostPosted: Tue May 29, 2018 9:09 pm
Car Model*:
1992 Dodge Dakota Starter V-6 or V-8 is the easiest 'cross reference'.
These are typically about $35 tops at local junkyards and fit all common high mount starter applications...
PostPosted: Thu Jun 14, 2018 6:02 pm
3 Deuce Webber
Car Model*:
Thanks again DI, do I need to remove anything from this starter as my truck has a relay for the starter? Thought I read something about this but can't seem to find it again.
Thanks again
PostPosted: Thu Jun 14, 2018 6:26 pm
Car Model*:
Is it a relay or solenoid? The 10 tooth starter equipped vehicles had the relay, and no mods needed... the 9 tooth starter circuit will
need to change as the starter already has the solenoid...
