It is currently Thu Apr 18, 2024 3:53 am
PostPosted: Thu Jan 30, 2020 6:10 am
Car Model: 1968 A108 225/3 on the tree
any recommendations as to where to find a 9R governor?
been a while since i dealt with mine. last i recall Napa was the best choice.
is that still the case?
PostPosted: Thu Jan 30, 2020 6:16 am
Unless you can lay your hands on a super six distributor, its just gambling when buying a reman distributor what you get for a governor....
The next best option is welding the existing slot or buying one of the 4secondsflat limiter wheels...
PostPosted: Thu Jan 30, 2020 6:29 pm
ur saying we can't go to a parts store and just order the governor we want seperately?
PostPosted: Thu Jan 30, 2020 9:24 pm
That would be correct...parts stores only carry the distributor as a full assembly... so you order a reman
distributor and take your chances... even Ma Mopar only would provide a governor with the fully assembled
shaft assembly for the distributor...so you would get the shaft, springs, counterweights, governor, clip,
and felt button as a unit if you ordered such a thing in 1978. That's why most discussions on recurves
usually get to the part about welding the slot, installing a spacer, installing the limiting wheel...or getting
lucky in the local junkyard and grabbing the 3874876 distributor....
If I could have ordered just the 9R governor in the past...I would have bought the lot and there would
have been a lot more DI recurves on the market... just sayin...
PostPosted: Fri Jan 31, 2020 7:41 am
ok. .
i get it. . .
i guess that limiter wheel could get it done.
i am not that good a welder for little stuff like this.
PostPosted: Fri Jan 31, 2020 6:43 pm
The four seconds flat plate is a good alternative forvwhat you are trying to do.
http://4secondsflat.com/Mopar%20Mechani ... 0plate.htm
PostPosted: Sun Mar 01, 2020 11:39 pm
thx.
this looks like a good idea.
PostPosted: Mon Mar 02, 2020 9:48 am
That is a pretty slick piece! I might have to order a couple. That sure beats filling and filing, although that information is available elsewhere on this site.
PostPosted: Mon Mar 02, 2020 11:54 am
Yep - - - fo' sho.
I don't have one yet but I think I have to go and by some of their stuff and try it out.
That Plate is simple but genius.
