It is currently Wed Apr 24, 2024 4:42 pm
PostPosted: Fri Aug 10, 2018 4:36 am
That will work very well, and will not perform much differently than the Howard or Oregon cams mentioned above. Have fun with your turbo buildup!
Home of Slant6-powered fun machines
PostPosted: Fri Aug 10, 2018 7:52 pm
If I remember correctly the ideal LSA for a NA 225 is 107 (give or take) and for a boosted 225 it's 114 (give or take)
For a NA 170 LSA would be 114. Does that mean a boosted 170 should have a LSA of 121?
PostPosted: Sat Aug 11, 2018 2:52 am
Hi Ed,
Do you know where your 114 for boosted 225 number originates? Kenny Duttweiler designed a cam for a (planned) turbo 170 Bonneville car and it is 116 LSA. I wonder if the 225 would want more like 112 LSA boosted. I bet there is a diminishing return for larger LSA on any engine. The valve sizes vs. displacement can only have so much effect when you are running substantial boost. This should be related to why turbo cams are not nearly as critical as NA cams.
PostPosted: Sat Aug 11, 2018 4:34 am
I was just using the 114 mentioned in this thread...……….
Just wonder if there is some sort of rule like start with optimum LSA for your engine and increase x degrees for every y psi boost.
Since a 170 should have a wider LSA than a 225 does it increase the same amount as a 225 would with boost.
I also think a 225 might need less boosted LSA than other engines because it's NA LSA is less than other engines.
PostPosted: Sat Aug 11, 2018 5:08 am
Ok, here we go:
https://www.hotrod.com/articles/ctrp-11 ... aft-guide/
PostPosted: Sun Dec 02, 2018 10:10 pm
Vgute wrote:
Ok got a email back from my grinder.
Intake duration @.050" 220° exhaust duration @.50" 220° and valve lift@ 1.5 rockers .450" for both. What are the thoughts? He has this as a master. Oh and is on a 114 lsa
This is pretty much my turbo cam. Did you get it and install it? I was thinking on going bigger lift, around .480 or more on the next one.
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Mon Dec 03, 2018 3:02 am
Howards has one that looks good too. Just need to ask them to open up the LSA a bit.
viewtopic.php?f=19&t=62844
