Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a New Year's donation to the Slant Six Forum!
Finding best valve lash setting
Goto page Previous  1, 2
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Engine
Select message display options:             View previous topic :: View next topic
Sam Powell
Post subject: (Tue Aug 07, 2007 7:26 pm) Reply with quote
Looser setting means less overlap, and more cylinder pressure, and more low end torque. I always ran my stock cams at .015 intake and .025 exhaust.
I got excellent mileage, in the twenties, and the sound was just that sweet clatter of good solid cams. One advantage is that out of spec ones tend to stand out more, and really rap audibly.
Sam
A REAL professional is someone who knows when to hit it with a bigger hammer.
Back to top
View user's profile Send private message Visit poster's website
Rug_Trucker
Post subject: (Tue Aug 07, 2007 7:34 pm) Reply with quote
Aggressive Ted wrote:
Jopapa,
What was your mileage before you set the valves?
and what were they set at before you changed them?
I was getting 18 mpg at .008 and .016.
After switching to .010 and .020, it went way up!
So thats double weird! Rolling Eyes
Interesting! I just thought mine went down because I drilled out my jets Laughing
'72 Duster 198 stock cam, 3:23's Hookers
'74Fart Dart Razz
'79 Maxivan 360 Offy Qjet Comp RV cam
93 D350 160HP Cummins Auto Sad Dually Clubcab
93 Corolla
Back to top
Jopapa
Post subject: (Tue Aug 07, 2007 7:48 pm) Reply with quote
Sam
I'll hafta try loosening them bit by bit to see if that affects mileage (and performance) at all for me. I figure I could start with the exhaust valves and leave the intakes where they're at for now, then once I find a good setting for the exhaust valves, work out the best setting for the intakes...
Back to top
Jopapa
Sam
Back to top
Rug_Trucker
Post subject: (Wed Aug 08, 2007 3:08 am) Reply with quote
I have been running mine set at .008 set cold intake and exhaust for a long time.
'74Fart Dart Razz
93 Corolla
Back to top
Post subject: (Wed Aug 08, 2007 8:34 am) Reply with quote
What kind of mileage are you getting?
Is it as bad as Jopapa's?
http://cid-32f1e50ddb40a03c.photos.live.com/self.aspx/74%20Dodge%20Dart%20Swinger
74 Swinger, 9.5 comp 254/.435 lift cam, ram air, electric fans, 2.5" HP2 & FM70 exhaust, 1920 Holley#56jet, 2.76 8 3/4 Sure-Grip, 26" tires, 25+MPG
Back to top
View user's profile Send private message Send e-mail Visit poster's website
Rug_Trucker
Post subject: (Wed Aug 08, 2007 7:43 pm) Reply with quote
I was getting 20-22 without the air. I drilled out the jets and it dropped to 16.7. Best mileage I got with the stock 1 bbl and head with a cracked exhaust manifold and the same mufflers was 29.5 at 65mph. Most of the time it got 25.5. All my mileage has been on 93 octane.
'74Fart Dart Razz
93 Corolla
Back to top
Jopapa
Post subject: (Fri Aug 10, 2007 2:31 pm) Reply with quote
Okay I've now got my valves set at 0.012 and 0.022. I'll slowly enlarge the gap in my exhaust valves until I see negative effects on my gas mileage, and then set them to what gave me the best mileage. Then I'll do the same with the intake valves. Hopefully this will help me find the best setting for my valves. I have a feeling I'm going to go through quite a few valve cover gaskets in the process here Rolling Eyes
Back to top
Rug_Trucker
Post subject: (Fri Aug 10, 2007 3:09 pm) Reply with quote
[quote I have a feeling I'm going to go through quite a few valve cover gaskets in the process here Rolling Eyes[/quote]
3M weather strip adhesive on the valve cover, and wheel bearing grease on the head side of the gasket. Old air cooled VW trick. You have to set the valves on a bug every 2000 miles.
'74Fart Dart Razz
93 Corolla
Back to top
polara pat
Post subject: (Fri Aug 10, 2007 5:40 pm) Reply with quote
Not to hi-jack your post but what would a good cold lash setting be after assembling a new motor. Maybe .008 and .018? then hot lash after break-in?
Back to top
emsvitil
Post subject: (Fri Aug 10, 2007 7:15 pm) Reply with quote
Cold lash .012 & .022
Back to top
Post subject: Mileage (Sat Aug 11, 2007 10:35 am) Reply with quote
Jopapa,
Let me know if your mileage changes with the wider lash.
Run another can of Seafoam through it too.
Back to top
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Engine All times are GMT - 7 Hours
Page 2 of 2
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
