Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a New Year's donation to the Slant Six Forum!
Re: Crush Sleeve & Rearend Set-up
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    Slant Six Forum, Forum Index -> Old Message Board
Select message display options:             View previous topic :: View next topic
Tim_K
Guest
Post subject: Re: Crush Sleeve & Rearend Set-up (Mon Jun 04, 2001 4:25 pm) Reply with quote
(User Above) wrote:
: I have never had that happen, may-be a
: defective "non-crushable"
: sleeve!?!
: Are you using new pinion bearings? Basically a
: crush sleeve is a cheap & easy way (when
: it works) to set the "preload" on
: the pinion bearings. Note that the older
: rears used selectable "shim-packs"
: to do the same thing. If the bearing are
: good used ones, then they will need less
: pre-load.
: Also note that the racers tend to replace the
: crush sleeve with a shorter solid sleeve and
: use shims to get the final pre-load needed.
: (this allows for a looser - less friction
: setting that will not "drift" with
: the pounding of race use)
: If you want to stay with the crush sleeve,
: either add a thin shim to the old one or
: take the old one and "hammer"
: around the bulge, this tends to expand the
: length slightly (measure before &
: after)then re-crush it to add bearing
: pre-load.
: DD
Got it working. After taking the entire axle to a friends' house, and with a total of 4 people holding the axle still and putting a piece of pipe on a breaker bar, the crush collar still wouldn't crush, so we did the trick of hammering around the edge of the old one to expand it. I kept track of it with a micrometer. The new one that would not crush was .470" thick, the old one when loose was .435"-.440", and after hammering, it was up to .450"-.455". We put it in and things went together nicely. Still had to put a lot of torque on the breaker bar to get it set right. Since I'm using all new pinion bearings and a new front seal, I let the bearings be a bit of a snug fit, requiring a slight amount of effort to spin the pinion gear without the ring gear being installed. After installing the carrier and making and using a tool to adjust the side adjusters down the axle tubes, it was ready to go.
After we were done, we thought for a while of if we should change axles that evening (last night) or not. After 15 minutes of debate, we decided to do it. We (2 people, Tim_K and one other person) set a new record for ourselves by changing the whole axle assembly in 2 hours, 18 minutes. If not for rusty threads on the axle to spring U bolts, we might have broken 2 hours. The new axle is quiet and runs well. The Sure-Grip locks up good and does not chatter like the old one did. The 3.90 gears are a HUGE performance increase over the old 2.71's, but highway cruising speed is not all that great, as expected. Can't have everything.
Back to top
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    Slant Six Forum, Forum Index -> Old Message Board All times are GMT - 7 Hours
Page 1 of 1
You can post new topics in this forum
You can reply to topics in this forum
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
