Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a New Year's donation to the Slant Six Forum!
home made parts bath how to?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    Slant Six Forum, Forum Index -> Old Message Board
Select message display options:             View previous topic :: View next topic
charlie d
Guest
Post subject: home made parts bath how to? (Sun Jun 03, 2001 7:02 pm) Reply with quote
as the parts and pieces of an ever-increasing list of overhaul/rebuild items accumulates about the shop and reassembly is underway, one thing is clear: i do not have a system.
i don't have any idea how to execute the tasks at hand even half-assed efficiently. i'm little more than a dishpig. not that i am above any honest work/manual labor. i'm just not on anyone's payroll for the work.
i have my utility dodge cargo van out of commission for service and repair, and i need to come up with a cost effective and timely method of part soaking and clean up.
could anyone suggest a workable set up and perhaps some tips on what technique's work best
thanks
Back to top
Doctor Dodge (Doug Dutra)
Guest
Post subject: Re: Cleaning Greasy Parts at Home (Tue Jun 05, 2001 11:43 pm) Reply with quote
(User Above) wrote:
: I need to come up with a cost effective and
: timely method of part soaking and clean up.
: Could anyone suggest a workable set up and
: perhaps some tips on what technique's work
: best
- Lay-down a old blanket or cardboard and scrap / wire brush all the heavy "crusted-on" grease off.
- Buy a can of engine degreaser, "Mr. Clean" or Oven Cleaner and use that to scrub the parts down.
- take a garden hose and attach it to your hot water heater. (my garage sink allow for hose attachment to the facet) Use a good "trigger style" nozzel and use gloves or wrap a rag around it's grip, it's gona' get hot!
- start blasting the scrubbed parts, dispose of the "waste-water" in an environmentally friendly way. (disclaimer, because where I live they will throw you in jail for washing an oil spot off your driveway and letting the run-off go into the storm drain)
Another option is the "doller car wash" or quote some local machine shops, they can get stuff really clean & nice for a fair price, shop around.
Back to top
matt
Guest
Post subject: Re: Cleaning Greasy Parts at Home (Wed Jun 06, 2001 10:32 am) Reply with quote
I'd like to add my product endorsments:
Castrol Super Clean' better degreaser than the spray engine clean, and carb cleaners, and sparybrake cleaners (I don't use it on carbs or brakes). Doesn't stink up the garage, so my wife doesn't complain.. It does make your hands very clean, but it dries the crap out of them. When you get that blue silicone on your pants, it does a good job of getting it out... If you use it to get stuff out of your hair, it really hurts the scalp, and your hair isn't the same untill it grows out...(long story..bad halloween costume choice is all I'll say).. and it seems to etch aluminum a little if you forget to rinse it... and one squirt makes the crickets spaz out for about 5seconds, and then they stop for ever.. same with spiders.. no other solvent gives me that kind of entertainment..
The Super Clean waterless hand cleaner.. goes on like lotion, rubs off like old elmers glue.. keep a tube in the travel tool box..
Paint remover is a great degreaser...use a paint brush, rub it till you get a black foamy gue, rinse it... The best is the mean, burn your skin type of paint stripper... but that orange enviro stuff, while not a great paint stripper, works real well on grease and dirt, and it doesn't stink the place up...
I like the oven cleaner idea, but I've never tried it..
harborfreight.com sells some cleap parts washers..
matt-
jimyrigg@hotmail.com
Back to top
GTS225
Guest
Post subject: Re: Cleaning Greasy Parts at Home (Wed Jun 06, 2001 11:29 am) Reply with quote
(User Above) wrote:
: I'd like to add my product endorsments: Castrol
: Super Clean' better degreaser than the spray
: engine clean, and carb cleaners, and
: sparybrake cleaners
And for those of you that build plastic models, it makes a great paint stripper when you screw up the paint job......WITHOUT hurting the plastic. Just submerge in a suitable container, check every 1/2 hour and scrub with toothbrush until satisfactory. (Don't use the toothbrush for your teeth anymore.)
Roger
gts225@aol.com
Back to top
Adam
Guest
Post subject: Re: Cleaning Greasy Parts at Home (Wed Jun 13, 2001 11:37 pm) Reply with quote
(User Above) wrote:
: And for those of you that build plastic models,
: it makes a great paint stripper when you
: screw up the paint job......WITHOUT hurting
: the plastic. Just submerge in a suitable
: container, check every 1/2 hour and scrub
: with toothbrush until satisfactory. (Don't
: use the toothbrush for your teeth anymore.)
: Roger
DOT 3 brake fluid also works great for removing paint from plastic items without harming the plastic.
For degreasing parts I like simple green and a scotch brite pad, oven cleaner works well on really nasty stuff, but you have to be careful with it as its pretty caustic.
Back to top
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    Slant Six Forum, Forum Index -> Old Message Board All times are GMT - 7 Hours
You can post new topics in this forum
You can reply to topics in this forum
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
