Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a New Year's donation to the Slant Six Forum!
What did you get done on your slant today?
Goto page 1, 2, 3 ... 231, 232, 233  Next
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Social Corner
Select message display options:             View previous topic :: View next topic
Joshua Skinner
Post subject: What did you get done on your slant today? (Sat Apr 04, 2009 12:26 am) Reply with quote
I thought it might be nice to share accomplishments and encourage others in their efforts. It's often easy to get bogged down or not do anything with a project for some time. Hopefully we can inspire each other.
My project which has spanned the past two weeks is all but wrapped up. I have rebuilt an A833 for my '67 Valiant. I'll be painting it black once it warms up a little which should be today or tomorrow!
I had never before taken an A833 completely apart, but with a '66 Dodge factory service manual and the 4-speed article on this board I made it through. I even made a tool to remove the reverse idler shaft. The parts budget took a $75 hit when I found a crack in the ring on the main shaft that separates second and third gears, but it's all together now. It's a shame the thing has to sit on the shelf and wait until I can afford a decent clutch and flywheel, but that's the breaks.
Joshua Skinner
car nut, telecom tech, tool using mammal
'72 Dart Swinger
Last edited by Joshua Skinner on Mon Mar 11, 2013 10:21 am; edited 4 times in total
Back to top
View user's profile Send private message
stonethk
Post subject: (Sat Apr 04, 2009 5:14 am) Reply with quote
That is inspiring, going through your transmission Josh.
Just yesterday I completed porting my head in under 4 hours and didn't hit a water jacket Laughing also matched my intake.
Next phase is block prep then clean up/balance my crank.
Back to top
wvenable
Post subject: (Sat Apr 04, 2009 5:42 am) Reply with quote
Thanks Josh for bringing up the encouragement word! Next couple of weeks I will be glass beading a cylinder head and then having it magnafluxed. I also have a junk head that I am going to band saw apart to help with port work. In the mean time saving up for some K1 rods. I want to thank forum members for their advice, education, and encouragement!
Back to top
sandy in BC
Post subject: (Sat Apr 04, 2009 6:12 am) Reply with quote
I watched the snow not melt. Its sposed to be warmer for a few days. Mebbe with a little shovelling I can spring the Valaint free of its snowy confines.....a new manifold and carb await.
Last winter was a long one....this one is at least 3 weeks longer. I still have a foot of snow in the spot there was 2" last year before MATS.....
http://www.arrowtipi.com/My%20Webs/index%20Valiant.htm
Back to top
View user's profile Send private message Visit poster's website
68barracuda
Post subject: (Sat Apr 04, 2009 6:46 am) Reply with quote
Rebuild the rear brakes on the CL Regal SE, spray painted some bits and pieces
Organized the transport of th 66 cuda I scored
Regards,
Fanie Gerber
Back to top
wjajr
Post subject: (Sat Apr 04, 2009 6:52 am) Reply with quote
We are stuck in a rain & fog New England Coastal weather pattern with temps in the low 40's, while waiting for the last foot of snow to go.
Friday I mounted two horns MiDi sold me, a rather lackluster day while waiting for a warm dry day to finish painting under the hood. (see below) However, Thursday I managed to remount all the relays and driver's side wire harness, battery tray, remove old radiator, mount a transmission cooler to a new radiator with all the plumbing & test fit it, finish prepping the block for paint, mask off freshly painted inner fenders & fire wall, paint the steering box, and clean up over spray on the "K" frame. Also test fit a new Bouchillon kick down cable, ordered a longer throttle cable from Rock Auto for the repositioned carburetor.
In a holding pattern waiting for the machine shop to finish the head with over sized valves, new hardened exhaust seats, a .075" shave, and a bit of porting.
Back to top
coconuteater64
Post subject: (Sat Apr 04, 2009 7:06 am) Reply with quote
Watched it rain. I don't have a garage. Sad
"Whoa, this thing has an inline six?"
"Nope, it's an INCLINE six!"
Back to top
Where is "global warming", when you need it? Laughing
66 Cuda 170 nitrous
66 Valiant Signet 225 nitrous
Back to top
vynn3
Post subject: (Sat Apr 04, 2009 10:45 am) Reply with quote
I pulled the windshield on the Swinger week before last, and last weekend I "fixed" the rotted out front edges of the windshield frame. (Have I mentioned how much I HATE vinyl tops?) Hoping to make the roof waterproof for the trip to Kearney this summer.
I've never done bodywork in my life. I debated on trying to learn to form sheetmetal patches and teach myself to weld, but chickened out, cleaned it down to bare metal, and used Por-15 epoxy putty to fill it all in. Smoothed it with bondo, sanded, primered, and it's all presentable for the first time in 10 years, at least on the surface. And more importantly, I'm hoping it'll repell the rain...
I know some folks will cringe with this ametuer, short-term approach, but getting the car ready for Kearney is my main concern right now. Thoughts?
vm
Back to top
View user's profile Send private message Yahoo Messenger
Andy's GT
Post subject: (Sat Apr 04, 2009 11:06 am) Reply with quote
i got my stratus mostly cleaned out inside and missed driving my dart in this beautiful (albeit slightly chilly) weather Confused
Back to top
Joshua Skinner
Post subject: (Sat Apr 04, 2009 11:13 am) Reply with quote
If that area stays dry your repair should last a very long time. Were you able to paint the inside? The only problem I see is if rust creeps in from the inside and gets in between the epoxy putty and the steel and the epoxy comes loose.
Joshua Skinner
'72 Dart Swinger
Back to top
MiDi
Post subject: (Sat Apr 04, 2009 12:00 pm) Reply with quote
i'm putting on a nice set of rear air shocks and NOZ!
Marilyn: FDB - 8.75 w/ 3.23 posi - 650cfm 4bbl - 4speed - shorty headers
Emma: FDB - 7.25 w/3.55 lock'r- 500cfm 2bbl - 904
Back to top
70valiant
Post subject: (Sat Apr 04, 2009 2:17 pm) Reply with quote
I soaked the intake/exhaust nuts, head pipe nuts and the nuts and bolts that hold the intake and exhaust manifolds together with croil. hopefully when I swap to a 2bbl next weekend none of the studs or bolts break.
I also painted the kickdown linkage.
Back to top
DusterIdiot
Post subject: My turn... (Sat Apr 04, 2009 5:54 pm) Reply with quote
Mowed the lawn and...LOL....
Car, that's right I have a car to work on...darn winter!!!
Next week the block should be back for the Pak2 motor. Had a Little League Game today and did yard work. Took time to look over my 'pile of A-833OD parts and it looks like I need to order some 308L bearings and get one put back together. I also took some time to clean and prep the 1976 K-member my buddy welded up/unitized and reinforced. Tomorrow if weather holds up I'll prime it. Once the Hpak duster goes back into circulation, Beater Valiant will be getting the late K-member and a suspension/brake/rear axle/steering/transmission overhaul....
Back to top
Jesus H Chrysler
Post subject: (Sat Apr 04, 2009 6:32 pm) Reply with quote
I washed it today. does that count? On Tuesday, I put in my new (used) interior panels. got em off ebay for 29 $ . I was amazed that someone had a set of panels for a 62 lancer gt, and...... They're even the same color! Razz I've been looking for those for years
Back to top
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Social Corner All times are GMT - 7 Hours
Page 1 of 233
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
