Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a New Year's donation to the Slant Six Forum!
Option for 73 904 flex plate
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Transmission & Rearend
Select message display options:             View previous topic :: View next topic
Turbo Toad
Post subject: Option for 73 904 flex plate (Thu Feb 23, 2012 7:40 pm) Reply with quote
I have a 73 motor and trans and I bought a 904 BM six bolt zero balance flex plate thinking it would bolt up to my crank flange NO LUCK
My question is what are my options for flex plates? This is for my turbo build and I hoping to make around 450 to 500 hp at the crank with a 3200 stall and a rev manual vavle body 904 also I'm running 2.94 suregrip 8.75 rear
I'll have to get some measurements of the torque converter distance between the bolt mounts for the flex plate in the morning
Thanks Aaron
Back to top
View user's profile Send private message
Turbo Toad
Post subject: (Thu Feb 23, 2012 10:00 pm) Reply with quote
I think I got the answer to my question on FABO there's only one bolt hole different on the small block crank flange and I can drill a new hole on the flex plate and weld the gap up sound right?
Thanks again KID
AARON
Back to top
bigslant6fan
Post subject: . (Fri Feb 24, 2012 5:45 pm) Reply with quote
Yes, me ,Slantzilla, and others have done the same thing,you'll have one hole shaped like a figure "8" . I bolted the two flex plates together with unthreaded shank bolts and washer stacks. Then drilled the needed hole undersize,then inlarged as needed with a round file.
V8?? We don't need no stink'n V8!!
Back to top
Turbo Toad
Post subject: Re: . (Fri Feb 24, 2012 7:28 pm) Reply with quote
I. Just got done doing it the same way u stated above thanks
Aaron
Back to top
Ceej
SSRN National Champion
Post subject: (Fri Feb 24, 2012 11:48 pm) Reply with quote
Lots of folks do the same thing, welding up the hole. Not critical. Shouldn't make any difference at the engine speeds a slant keeps the rods enclosed at.
CJ
Tyrde-Browne Racing
I'm off to find myself. If I should return before I get back, keep me here.
Back to top
View user's profile Send private message Send e-mail
Turbo Toad
Post subject: (Sat Feb 25, 2012 12:41 am) Reply with quote
Here's how I did mine
U can see the new bolt hole in the second pic
Aaron
Back to top
Dart270
Post subject: (Mon Feb 27, 2012 7:43 am) Reply with quote
Yep, been there done that!
Balancing out the driver's weight for more than 50 yrs
Back to top
Turbo Toad
Post subject: (Mon Feb 27, 2012 8:50 am) Reply with quote
Lou I haven't had a chance to check to see about the oil pan pick up but I do still need one ill do some research in the next day or too and let you no
Aaron
Back to top
bigslant6fan
Post subject: . (Mon Feb 27, 2012 7:36 pm) Reply with quote
The flexplate in your pic looks like the wrong one. It looks like the larger 727 one that will not clear the bellhousing and starter on a 904.
Back to top
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Transmission & Rearend All times are GMT - 7 Hours
Page 1 of 1
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
