Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a New Year's donation to the Slant Six Forum!
Hi from new (old) guy
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Social Corner
Select message display options:             View previous topic :: View next topic
Rex Baker
Post subject: Hi from new (old) guy (Fri Feb 24, 2012 9:27 am) Reply with quote
Just want to say hi & introduce myself and also thank the forum for allowing me to join. I need much help with slant 6's. I have had many Mopars since early 70's but all have been v-8's. Prior to that (60's) I was pretty much a GM guy with occasional Mopars. My Pop converted from Packard's to Plymouth's around 1957 so we'd give each other a hard time.
Last year I converted my 63 sport fury cv to a Slant 225, from the original 383hp motor as it's my dedicated 'driver' to fun events. We love to travel and my old 6bbl roadrunner just doesn't get very good mileage. The Slant 6 has worked great but it was an old, tired motor & I now have several parts motors that I'm going to try & make one fresh one from. I did acquire a 2bbl intake that I'll be converting to a tbi unit in the future, after I get a good motor put together. And, I need help so I'll be on the engine forum, real soon! Thank you in advance for your help!
Rex
Sport Fury
Back to top
View user's profile Send private message
Rob Simmons
Post subject: (Fri Feb 24, 2012 9:31 am) Reply with quote
Welcome to the Forum Rex! Very Happy
This is definitely the place to find any and all information related to the Leaning Tower of Power! Wink
Looking forward to reading about your progress. There is a Slixer's Gallery section where you can start a thread telling about your Fury and post pictures. We'd love to see it!
I want to "Slant" the world!
... one vehicle at a time...
Back to top
Slanted Opinion
Post subject: (Fri Feb 24, 2012 9:56 am) Reply with quote
Welcome! Glad you're here!
There are a million good hints here, and many folks that will be happy to assist you in your build.
Regarding TBI: Some have done it. I won't say it's a bad thing, but my impression is that there isn't much to be gained by it. You end up with a great "mixer" at one end of the manifold, but still have all the issues of fuel distribution to battle with. Gains in economy and power tend to be small for TBI slants.
That's my $.02. Wiser and more experienced slanters may have a better take on TBI than myself.
In all slant projects... have fun!
- Mac
Back to top
Dart270
Post subject: (Fri Feb 24, 2012 10:08 am) Reply with quote
Welcome! Sounds like a fun project. I have quite a bit of TBI experience on my '64 Dart, and it will likely be worth it if you use a megasquirt or some laptop-tunable ECU.
For a mild/medium motor, I would use a 2bbl Holley TBI from a GM 4.3L V6, or something similar. Maybe a Mopar (Holley TBI also) 3.9L 2bbl. I am contemplating doing this on my new '64 Valiant driver.
Yes, MP-EFI is better, but the TBI will allow more tunability than any carburetor, if you set it up right.
Return of the 64 Dart. Hang on...
Back to top
SlantSixDan
Post subject: (Fri Feb 24, 2012 10:39 am) Reply with quote
Welcome here! Tune-up parts and technique suggestions in this thread. Remember the mechanical tappets will require periodic valve adjustment. Until you change over to fuel injection, Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
Sure, port fuel injection is the best, but TBI with good hardware and software is definitely going to give you better driveability and mileage than a carburetor. There are no such giant big mixture distribution problems with the slant-6 as there are on other inline-6 engines with their log/rake type intakes. Some thought and effort will address the relatively minor such issues; rather than using the factory 2bbl intake, you would likely do better to modify a 1bbl intake into a parallel 2bbl setup. Photo documentation of a very well done such conversion is here.
As for hardware: Having lived with the pathetic Mopar TBI system ('88-'91 Dodge trucks and vans, 3.9/5.2/5.9) on my '89 D100 318, I would definitely not select any part of it for retrofitment. Its hardware and firmware/software are poorly designed, halfassed and primitive. If I were going to the effort to retrofit TBI, I would use GM hardware -- adaptor plates are readily available and there's a wide range of injectors to get whatever flow rate you need -- and a reprogrammed GM computer (you can do that with the GM computers, but not with the Mopar ones). See discussion here, here, here, and here. Dart270's hardware suggestions (GM 4.3 V6) are good. You might experiment with a factory 4.3 computer, either stock or rechipped, before investing the time and money in Megasquirt or similar. You will want to use a late-model exhaust manifold that has a threaded port for you to install an O2 sensor, which enables closed-loop operation key to efficiency with fuel injection (or at least the rear half of a late-model exhaust manifold…see Dutra Duals).
Adding a vehicle speed sensor is easy; a NAPA Echlin VSS-232 (or equivalent) can simply be placed in line with the speedo cable:
By birth & parentage: US citizen, 2nd class
By choice: Canadian citizen, 1st class
Back to top
View user's profile Send private message Visit poster's website AIM Address
Rex Baker
Post subject: (Fri Feb 24, 2012 10:41 am) Reply with quote
Thank you for the welcomes. I'm going over to the picture section to see if I can figure out how to post some of the SF.
The reason I'm considering the tbi is twofold. I've done several 4's & v-8' already, using factory ecm/sensors/tbi's, usually gm and the second is I'm only going for fuel mileage, not really a power increase. Also, it's pretty easy to convert to tbi!
Sport Fury
Back to top
walpolla
Post subject: (Fri Feb 24, 2012 9:17 pm) Reply with quote
And welcome from Australia. Lots of Slants down here too.
regards,Rod. Very Happy
Back to top
Ceej
SSRN National Champion
Post subject: (Fri Feb 24, 2012 10:15 pm) Reply with quote
Welcome to /6 dot org!
Our community is all about helping each other and our attachment to the slant six.
Enjoy your time here!
CJ
Tyrde-Browne Racing
I'm off to find myself. If I should return before I get back, keep me here.
Back to top
View user's profile Send private message Send e-mail
Slant Cecil
Post subject: (Fri Feb 24, 2012 10:52 pm) Reply with quote
Welcome Rex.
Hey Dan,
the NAPA Echlin VSS-232 hasn't been available for several years. It crosses to an early '80 Buick with cruise. I struck out with the other parts store chains and had no luck at three different You-Pull-It yards for a used one. I was wanting one to signal my aftermarket cruise, ended up with the magnets on the driveshaft. Do you know of any others?
Slant Cecil
'68 V100, 225-2, 904 - ???
'68 V200, 225-1, 904 - 18.19@74
'68 Signet, 225-2, 904 - 17.42@79
'79 Aspen, 225-2, 904-???
'82 D150, 225, 833OD
'84 D100, 225, 833OD
Back to top
Sam Powell
Post subject: (Sat Feb 25, 2012 6:17 am) Reply with quote
Welcome Rex. I am eager to see your 63 Sport Fury. Had a friend with one back when new.
Sam
A REAL professional is someone who knows when to hit it with a bigger hammer.
Back to top
Rex Baker
Post subject: (Sun Feb 26, 2012 10:18 am) Reply with quote
Thank you, again for the welcomes. I did post a few photos of the SF on the social page. As I said on there, I can go weeks & not get on these websites but I will try to contribute if I can. I do have a couple grade school buddies that have a wrecking yard that they won't sell stuff out of but very nicely, they let me 'pick through' & find stuff for my various projects. This is why I refer to most of my cars as 'junkyard specials'. Laughing Here's a few pictures.
Slant donor!
Sport Fury
Back to top
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Social Corner All times are GMT - 7 Hours
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
