Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a New Year's donation to the Slant Six Forum!
Show & tell: your home-made "specialty" tools.
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Social Corner
Select message display options:             View previous topic :: View next topic
Red
Post subject: Show & tell: your home-made "specialty" tools. (Sat Apr 21, 2012 7:03 pm) Reply with quote
Most of the specialized tools that Miller made for the slant are long out of production and expensive if you can find them.
I'm also "on a budget" (read, "cheap"), though far be it from me to point fingers at any of the rest of you Wink .
So I try to fabricate whatever special-purpose tools I can. Here's my latest attempt: a con rod balancer:
Hoping this will help me get each end of each rod of a set in the same ballpark, weight-wise, in addition to having each whole rod weigh about the same.
I'm sure many of you longtime racers and self-reliant farm boys are way ahead of me and could fill pages with the stuff you've fabbed. Do share some of your favs...
obliquely-inclined state of mind
Back to top
View user's profile Send private message
Red
Post subject: (Sat Apr 21, 2012 9:03 pm) Reply with quote
Torsion bar remover:
Back to top
armyofchuckness
Post subject: (Sun Apr 22, 2012 5:00 pm) Reply with quote
That's a very cool set of tools. Your torsion bar tool looks more efficient than the one I bought on eBay. Look forward to seeing more ingenious solutions.
Project Valiant Blog
Back to top
View user's profile Send private message AIM Address
Red
Post subject: (Sun Apr 22, 2012 5:58 pm) Reply with quote
Thanks.
The balancer is obviously not a "high-precision" fixture, (though I did my best to insure that a centerline through the axis of the bolts to which the rod ends mount is parallel to the base upon which the scale rests and that all is plumb and level). In any case, I figure it will get me closer than "just eye-ballin' it". Repeated weighings of a given rod end (removing the rod from the fixture between weighings) yield identical results with only an occasional gram of variance.
The torsion bar tool works real well. Provides a nice, big, solid surface to strike and, despite attaching to the torsion bar firmly, has no sharp edges which might mar the bar's surface and create spots where stress risers could start. Scratching or scoring your torsion bars is a "no-no".
Back to top
Red
Post subject: (Sun Apr 22, 2012 9:08 pm) Reply with quote
Here's another: the "piston stuffer":
Your headless engine is on the engine stand, ready for the ringed pistons and rods to go in. The pivoting tube at the far left end of this device gets bolted to the engine deck with a head bolt. The arm further up the handle also pivots as does the wooden cylinder at the end of said arm. The handle acts as a lever with which to press down on your new piston top in order to shove the piston down the ring compressor and into the waiting cylinder. The head and nut of the bolt on which the wooden cylinder pivots are both counter-sunk so that they will not score the cylinder walls.
This allows you to stand on the crank side of the engine (as opposed to tapping the piston into the cylinder from the deck side). It also frees up a hand which can be used to guide the rod bolts around the rod journals as the piston goes in.
I sincerely apologize to any certified welders in present company who may find my chewing-gum welds to be highly offensive.
Back to top
hantayo13
Post subject: (Mon Apr 23, 2012 5:42 am) Reply with quote
have made several special tool for my harley ...two different clutch spring compressor ,one old style and one new....a 6 inch long 1 5/16 socket for final drive nut ...an 8 1/8 x 3/4 rod to hold wheel bearing spacers in place while installing wheel....all work well
Back to top
View user's profile Send private message MSN Messenger
Red
Post subject: (Tue Apr 24, 2012 11:12 pm) Reply with quote
Well, these two aren't home-made. But I like 'em so much that I'm gonna add them.
This bad boy beats a pickle fork all t'hell when it comes to poppin' apart front suspension:
This KD compressor is total overkill for slant valve springs. Sure does make short work of disassembling a head:
Back to top
Volare4life
Post subject: (Fri Apr 27, 2012 1:33 pm) Reply with quote
damn fine monster pickle tie rod/pitman arm puller you got there Red, what brand, and is it still available ??
-Mike
Back to top
View user's profile Send private message Yahoo Messenger
Red
Post subject: (Fri Apr 27, 2012 2:47 pm) Reply with quote
Volare4life,
I got mine years ago from Eastwood, but they don't seem to carry it anymore.
Here's something similar, though I can't tell if it's the same size or not:
http://www.northernautoparts.com/ProductModelDetail.cfm?InventoryId=517089
I also seem to remember having seen one for sale or loan at Kragen's or O'Reilly's at some point.
It's a really versatile puller.
Back to top
Volare4life
Post subject: (Fri Apr 27, 2012 10:59 pm) Reply with quote
yea found somthing similiar at harbor freights site http://www.harborfreight.com/5-piece-front-end-service-tool-set-66686.html
-Mike
Back to top
Red
Post subject: (Sat Apr 28, 2012 6:24 am) Reply with quote
I try to stick with US-made stuff these days, so I don't buy from Harbor any more. Among other reasons, because what they sell is a real mixed bag, quality-wise. Some of it is good, but a lot of it is junk. Can't say which that particular set might be.
Back to top
wjajr
Post subject: (Sat Apr 28, 2012 6:31 am) Reply with quote
Ball joint separator used to pop lower or upper ball joint free of spindle without damaging dust boots.
Front end bushing installing and removal tool from the plumbing aisle:
Old guy’s easy under dash access device. Just select proper width two by dimensional lumber for hours of comfy kink free projects. Also doubles as work platform to engine compartment when car is jacked up:
Back to top
zorg
Post subject: (Sat Apr 28, 2012 10:36 pm) Reply with quote
Red, your T-bar tool is much nicer than mine. I may have to copy you next time around...
I read about this one online somewhere, and just got to use it for the first time today.
I had to keep pretty good pressure holding the air nozzle against the canister (well duh, I was putting 60psi in there...), but it worked dandy. Sure beats the little hand pumps they sell that screw onto the gear oil jugs. Oh, and it was only $8!
Wjajr, I did most of the bushing on my front end much the same way as you, but not sure where the pictures are right now.
Back to top
View user's profile Send private message Visit poster's website
Red
Post subject: (Sun May 06, 2012 1:14 pm) Reply with quote
Scrap wood valve organizer:
Back to top
Fopar
6 Pack Dart
Post subject: (Sun May 06, 2012 1:41 pm) Reply with quote
How about a tubing bender.
Richard
Back to top
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Social Corner All times are GMT - 7 Hours
Page 1 of 3
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
