| Author |
Message |
Guest
Newbie intro....
(Thu Dec 12, 2002 2:02 pm)
| Howdy from a South Texas slant sixer, well not quite a slant six owner yet. Tonight I should seal the deal on an 1/2 ton Dodge pick up with a slant six and granny gear 4 spd. I have been looking for one for quite awhile. Had a 77 with 3 on the tree, wished I never sold it. When I was 18 if someone told me I actually would be excited about gettin a slant six, I would've told them your crazy. Cant wait!!
| Back to top |
Bruce Johnson TBI Slant 6
(Thu Dec 12, 2002 4:43 pm)
| Welcome back! Sounds like another truck is going to get proper attention
_________________ 78b4ramSnortbed/6
| Back to top |
Doctor Dodge Guru
Joined: 12 Oct 2002 Posts: 3188 Location: Sunnyvale, Calif.
(Fri Dec 13, 2002 12:52 am)
Good luck on the new purchase.
Boy, If I had only kept some of the cars I sold years ago....
| Back to top |
slowpoke 1 BBL (New)
(Fri Dec 13, 2002 9:25 am)
| Its a done deal, an 82 SWB /6 4spd, very little rust and runs great. Got ittfor 700.00 Does need fresh paint and door panels( missing) Seats and dash are great shape no tears or cracks. Thanks for the welcome, look forward to hangin out here as I refurb. the truck.
| Back to top |
Super6 Board Sponsor
Joined: 14 Jan 2003 Posts: 618 Location: Fairbanks, AK
(Mon Jan 20, 2003 7:26 pm)
I figured this was as good a place as any to introduce another newbie to the board. Hi to everyone here, and hi to those who frequent slantsix.com.
-Aaron_________________ The "Silver Bullet"
87 Ram D150
| Back to top |
(Thu Jan 23, 2003 9:43 pm)
| looks like a nice straight body Whats the drivetrain like? Bruce Johnson
| Back to top |
dodge_this! 4 BBL ''Hyper-Pak''
Joined: 08 Nov 2002 Posts: 29 Location: New Castle, IN
(Fri Jan 24, 2003 11:08 am)
| Hey. I have an 85' D100 that I would like to set up. Let me know how you do. And if you have any tips let me know.
| Back to top |
(Fri Jan 24, 2003 12:28 pm)
looks can be deceiving...she does need some TLC on the body in a few places..fortunately one of my friends is all tooled up to run his own body shop out of his garage
Drivetrain...(currently)
MP .398" lift 240 dur purple shaft hyd. cam (plan to go bigger..somewhere around .490" and 260-270 dur)
MSD 6A ignition, wires, & Blaster2 coil and stock electronic dist (replaced the lean-burn dist and ignition)
clifford 3x2 headers to true 2.25" duals w/ flowmaster 40 series muffs
Supersix intake w/ BBD (Just got my offy 4bbl intake & Holley 390 cfm in the mail yesterday )
Stock trans (auto A999) and TC (plan to upgrade the TC to around a 2400-2500 stall when i go bigger on the cam)
Stock 8 3/8 rear w/ 2.76:1 gears and limited-slip (UGH--will be changing thos highway dogs to 3.55:1)
K&N 14" x 3" open element air filter
MP high-volume oil pump
And all the smog equipment "fell off" (ditching the lean burn got rid of about 2 miles of vacuum lines and..go figure, made it run MUCH better, with lower emissions!)
As I said I just got my offy 4bbl intake and Holley 4 bbl carb..but i am going to pull the head before i install them and do some work (im pretty sure i burnt a valve on #1 anyway (BBD throttle shaft wore out--running way too lean) Plan to have Ford 300 valves installed, mill the head .080-.100 to get comp up to about 9.5:1 (wont be sure on how much to mill until i take it apart and take some measurements/cc the head) and do some mild porting.
Ive been toying with the idea of getting 1.7:1 roller rockers, but at the current time am leaning towards getting a bigger cam instead.
After all is said and done i want to paint the block & head CAT yellow, the intake and headers silver, and the usual chrome suspects. However, before making the engine "purty" i need to get the body blemishes fixed and get the old girl a new paint job.
87 Ram D150
| Back to top |
Buddy Le 2 BBL ''SuperSix''
100 bucks and i got a 81 lebarron with a slant 6
(Thu Jan 30, 2003 9:47 pm)
yeah im realy new to this my old car died i was poor i found a 81 lebarron with a solid body for 100 bucks from a freind and it got me 1100 miles on it so im totaly new to the slant 6 experience i hope this car has potential i like it i like a car where i can get under the hood and actualy identify the parts to some extent already have put a new clutchfan in it plugs breaks tires so far its still a resonable car for the poor college wallet
does this 81 engine have any potential.
buddy le
| Back to top |
