Slant Six Forum https://www.slantsix.org/forum/ |
Happy Carter BBD Rebuilder https://www.slantsix.org/forum/viewtopic.php?f=11&t=15303 |
Author: | Daddiojoe [ Wed Dec 07, 2005 6:16 am ] |
Post subject: | Happy Carter BBD Rebuilder |
After going through three junkyard/ebay rebuild-it-myselfs, including getting rebushed at a machine shop, I broke down and spent $125 plus shipping for a rebuilt BBD from CARB SPECIALISTS 1-888-871-CARB. Runs great, one year warranty, and nice service. It's made a big difference in my life, as my /6 is a daily driver. Thought you'd like to know, Joe |
Author: | Rust collector [ Wed Dec 07, 2005 11:32 am ] |
Post subject: | |
Great! |
Author: | Reed [ Wed Dec 07, 2005 11:53 am ] |
Post subject: | |
Is it a slant six specific BBD? |
Author: | CRANKSNAPPER [ Fri Nov 01, 2019 3:39 pm ] |
Post subject: | Re: Happy Carter BBD Rebuilder |
BBD Y-E-S ! WITH AN OFFENHAUSER 4BBl INTAKE I TRIED THE 4-SERIES & THE YF's, AND THE BBD WAS THE ONLY UNIT THAT STOPPED THE OFF-IDLE STUMBLE. BUY ALL THAT YOU CAN. AN ASIDE: THE a904 OUTPUT SHAFT BEARING IS OBSOLETE (FAG 2A836) I.D. 1.1645" [/u] O.D. 2.44" W. .63'. SNAPRING ALTERNATIVE WORKS WELL: (6206) NO SIDE SEALS I.D. 1.181" O.D. 2.44" W. .63" SNAPRING https://www.ebay.com/itm/1-pc-6206-open ... 8122!US!-1 YOU CUT 3.5" LENGTH OF .008" FEELER GAGE AND SLIDE IT BETWEEN SHAFT & I.D. https://www.ebay.com/itm/008-Thick-1-2- ... SwMmBVpBc2 N-O-W EMERSON BEARING HAS 4 ORIGINAL BEARINGS LEFT. I SCOURED WORLDWIDE AND FOUND SOME FROM GERMANY (FAG 2A836's)……. BUT I LIKE MY ALTERNATIVE BETTER...….$9...….INSTEAD OF $54. SINCE I BUILD RACE A904's THIS IS A GOOD SETUP. KNISELY TRANSPORTATION 425806520NINE |
Author: | Killer6 [ Thu Nov 07, 2019 4:28 pm ] |
CRANKSNAPPER wrote: BBD Y-E-S ! WITH AN OFFENHAUSER 4BBl INTAKE I TRIED THE 4-SERIES & THE YF's, AND THE BBD WAS THE ONLY UNIT THAT STOPPED THE OFF-IDLE STUMBLE. BUY ALL THAT YOU CAN. AN ASIDE: THE a904 OUTPUT SHAFT BEARING IS OBSOLETE (FAG 2A836) I.D. 1.1645" [/u] O.D. 2.44" W. .63'. SNAPRING ALTERNATIVE WORKS WELL: (6206) NO SIDE SEALS I.D. 1.181" O.D. 2.44" W. .63" SNAPRING https://www.ebay.com/itm/1-pc-6206-open ... 8122!US!-1 YOU CUT 3.5" LENGTH OF .008" FEELER GAGE AND SLIDE IT BETWEEN SHAFT & I.D. https://www.ebay.com/itm/008-Thick-1-2- ... SwMmBVpBc2 N-O-W EMERSON BEARING HAS 4 ORIGINAL BEARINGS LEFT. I SCOURED WORLDWIDE AND FOUND SOME FROM GERMANY (FAG 2A836's)……. BUT I LIKE MY ALTERNATIVE BETTER...….$9...….INSTEAD OF $54. SINCE I BUILD RACE A904's THIS IS A GOOD SETUP. KNISELY TRANSPORTATION 425806520NINE That's a heck of an aside,....lol! But thanks for posting that info, really, a lot of stuff is dryin' up for some of Us in the hobby/life. |
Author: | Killer6 [ Thu Nov 07, 2019 4:30 pm ] |
Post subject: | Re: |
Rust collector wrote: Great! X2, always good to hear of a good product/service out there.......... |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
