| Slant Six Forum https://www.slantsix.org/forum/ |
| 1980 Chrysler Racer Found!! Airport Tug https://www.slantsix.org/forum/viewtopic.php?t=44316 |
Page 1 of 2 |
| Author: | Rick Covalt [ Sat Apr 02, 2011 1:50 pm ] |
| Post subject: | 1980 Chrysler Racer Found!! Airport Tug |
A well hidden barn find was discover and brought to my home today. It has some very obvious race features that I will point out as you look at the pictures. Vital statistics are: 225 Industrial engine and automatic transmission with gear reduction rear end. Total weight as built 5850#. Built in 1980. I am a little puzzled why an obvious racing vehicle has a passenger seat in it. Any help would be appreciated. ![]() Obvious, Big tires on the rear and skinnies on the front. ![]() Super low front facia made of 1/2" plate. Ground clearance 1 1/2" Aero should be great ![]() Not sure if this is for the wheelie bar or the parachute. See stainless zommie in the lower right. Also has a 1 1/2" thick plate 30" square mounted on it to aid with traction. ![]() Factory ratchet shifter proves this was for racing. Also see the parachute lever beside it. ![]() Passenger side Alternator for better weight distribution. ![]() Factory dual ballast racing ignition system. Well, that is enough of the craziness. There are a lot of good parts on this thing. Some things I will use some I will sell. If you see something you want let me know. Basically I got it for the engine and tranny. The electronic ignition, alternator, and starter are all things I can use. Once I start dismantling it I will put a post in the for sale section. Rick |
| Author: | Dart270 [ Sat Apr 02, 2011 2:03 pm ] |
Yer a nut, Rick. You mean you don't want to race me on my bicycle at M-D? I am not kidding... Nice find... Lou |
| Author: | sandy in BC [ Sat Apr 02, 2011 2:13 pm ] |
That cooling fan could be used for propulsion ! I like the Slingshot seating arrangement..... Getter down to 1800 lbs and I think it could be competitive......might be awkward at 117mph in the lights though..... |
| Author: | Rick Covalt [ Sat Apr 02, 2011 2:14 pm ] |
| Post subject: | Nope! |
Quote: Yer a nut, Rick
You're right on that one. But I really just think your jealous! It will be dismantled long before Mason Dixon for the $$$ Scrap prices on 5000# are pretty good. Besides, I don't want to be embarrassed! It does have a 727 with a e-brake mounted on the tail shaft. The tail shaft may be a little shorter too, but it is buried in this thing so I can't see it very well. Has rear end that aims rearward into some kind of gear reduction. Someone may want that for somthin! Rick |
| Author: | Rick Covalt [ Sat Apr 02, 2011 2:16 pm ] |
| Post subject: | Weight? |
Quote: Getter down to 1800 lbs and I think it could be competitive
1800? You mean 3800# right? I also forgot it has a straight axle and leaf springs, so it has that whole "gasser" thing going for it too! Rick |
| Author: | wjajr [ Sat Apr 02, 2011 2:33 pm ] |
One mustn’t discount that fine bovine paint scheme. |
| Author: | Dart270 [ Sat Apr 02, 2011 2:41 pm ] |
Y'all have green cows in Maine? Lou |
| Author: | emsvitil [ Sat Apr 02, 2011 2:56 pm ] |
You forgot to mention the great aerodynamics........... |
| Author: | slantzilla [ Sat Apr 02, 2011 3:06 pm ] |
Get it running and drive it around for awhile. That's a nice specimen of a small luggage tugger. |
| Author: | Joshie225 [ Sat Apr 02, 2011 3:11 pm ] |
Luggage? Do you really need something that weighs 3 tons with driver for luggage? |
| Author: | Rick Covalt [ Sat Apr 02, 2011 3:20 pm ] |
| Post subject: | Yes! |
I'm pretty sure that it was used for the big luggage trailers at the airport. Did you ever weigh your wifes luggage when she went on a trip? Multiply that by a couple hundred. It has power brakes that are big. Maybe 4" wide from what I can see. Rick |
| Author: | SlantSixDan [ Sat Apr 02, 2011 3:25 pm ] |
Y'all missing the point. It's not for hauling luggage, it's for crushing luggage.
| Author: | Rick Covalt [ Sat Apr 02, 2011 3:29 pm ] |
| Post subject: | This is fun! |
I'm having fun with this. I entertain easily! Forgot it had a tilt front end too!!
| Author: | wvenable [ Sat Apr 02, 2011 3:33 pm ] |
Big D is quite right. Get it runnin' and drive it around the neighborhood! |
| Author: | Rick Covalt [ Sat Apr 02, 2011 3:53 pm ] |
| Post subject: | Mower |
Well as small as it is I guess I could mount a mower on it and mow my grass. It would be a Mower/ roller combo. Rick |
| Page 1 of 2 | All times are UTC-07:00 |
