It is currently Fri May 17, 2024 10:11 pm
PostPosted: Sun Oct 02, 2022 3:59 am
hi and hello:
Just found out the GOODSON ST-437 tool for removing wheel studs on a 9 in drum is no longer available. Anybody know where I can get one?
I need to replace a single wheel stud on a 9 in drum for a 1968 DODGE DART 270/SL-6 all original. A cute car w/o muscle power but a fun car to enjoy at car shows.
Thx....great forum. Long live SL-6 and MOPAR.
"1968 Dodge Darts forever"
"1968 Dodge Darts for ever"
PostPosted: Fri Oct 07, 2022 11:46 am
I have read that a 5/8 metal cutting hole saw minus the pilot bit will do the job. A word of caution do not try to press out the studs without cutting off the swedge or you will ruin your front hubs. I actually had a well-known machine shop do this to my original spindles in the mid 80s so I know first-hand.
63 Plymouth Valiant Wagon
PostPosted: Fri Oct 07, 2022 4:35 pm
The last ones I changed, I simple cut off the stud close to the swage, and then drilled series of holes till I was close to the size of the hole. Take a round punch and gave it a wack or two and they came right out. Just make sure the first hole is pretty well centered. Worked fine for me.
