It is currently Fri Apr 03, 2020 12:37 am
 Post subject: Numbers help needed
PostPosted: Tue Oct 12, 2004 7:21 am
Car Model*:
I need some help figuring out what I have. Engine: looking at the block from the driver's side...looking to the left of the exhaust pipe, I see the raised numbers: 030-12, and on the right side of the exhaust (closest to the firewall) I read 0047. Does this give me the info on what year block I have? Also, the carb, single barrell, has the numbers 6-1695 on the driver's side. What do I have?
PostPosted: Fri Oct 15, 2004 5:31 am
Car Model*:
OK...figured out the carb. Its a Carter BBS. Local parts store actually had one in stock! Still like to know what year motor is in the car.
PostPosted: Fri Oct 15, 2004 8:13 am
Car Model*: Many Darts and a Dacuda
The casting numbers on the driver's side of the block doesn't do much for telling us the year of the engine. In general, it does sound like a 77 and later cast crank block.
Take a look to see if you can find some stamped numbers in the pad by the alturnator or on the side pad back at the rear of the valve cover.
Users browsing this forum: No registered users and 17 guests
