Slant Six Forum https://www.slantsix.org/forum/ |
170 cam https://www.slantsix.org/forum/viewtopic.php?f=19&t=28721 |
Author: | heckshemi [ Sat May 03, 2008 11:45 am ] |
Post subject: | 170 cam |
I'm building a 170 for a daily driver and can't decide on a cam. Compression ratio will 10.0 to 1 or more depending on cam. Larger valves and port work. I've got a stock cam and a Erson 270. I think the Erson may be to much in a 170 with stock converter. Would the Comp 264 be a better choice? I want a good idle, good low and midrange, but not done at 4500. |
Author: | Doctor Dodge [ Sat May 03, 2008 8:59 pm ] |
Post subject: | |
Have Erson grind you a "special" RDP cam, 266 on the intake and 244 (254) on the exhaust. See this link for the detailed specs DD |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
