Slant Six Forum https://www.slantsix.org/forum/ |
Levelling a slant https://www.slantsix.org/forum/viewtopic.php?f=19&t=66509 |
Author: | justa170 [ Sat Mar 19, 2022 10:26 am ] |
Post subject: | Levelling a slant |
Halp! What part(s) of a slant sit level with respect to the ground (apart from the bottom of the oil pan, which is tricky to stick an angle finder to)? I am currently trying to set the 3-degree slant correctly on a T-bucket installation. |
Author: | Charrlie_S [ Sat Mar 19, 2022 11:09 am ] |
Post subject: | Re: Levelling a slant |
justa170 wrote: Halp! What part(s) of a slant sit level with respect to the ground (apart from the bottom of the oil pan, which is tricky to stick an angle finder to)? I am currently trying to set the 3-degree slant correctly on a T-bucket installation. Carb mounting pad on the intake manifold. |
Author: | justa170 [ Sat Mar 19, 2022 4:07 pm ] |
Charrlie_S wrote: justa170 wrote: Halp! What part(s) of a slant sit level with respect to the ground (apart from the bottom of the oil pan, which is tricky to stick an angle finder to)? I am currently trying to set the 3-degree slant correctly on a T-bucket installation. Carb mounting pad on the intake manifold. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
