Slant Six Forum https://www.slantsix.org/forum/ |
I meant pressure plate bolts! Oof. [Requesting Help: Choosing Flywheel Bolts] https://www.slantsix.org/forum/viewtopic.php?f=19&t=67636 |
Author: | justa170 [ Mon Feb 12, 2024 10:22 am ] |
Post subject: | I meant pressure plate bolts! Oof. [Requesting Help: Choosing Flywheel Bolts] |
I'm stuck! How do I choose flywheel bolts? I called ARP and said, "Slant six with a stock '64 Dart 122-tooth flywheel and a Centerforce DF228035 pressure plate." The guy said, "Call Centerforce?" (I mean, I don't blame him. I don't know how thick the flywheel is, offhand, so I couldn't tell him.) Before I call Centerforce (and they say "Call Stellantis?" ![]() Do I want ARP #240-2801? (Threads are 7/16-20; UHL is 0.875".) https://arp-bolts.com/kits/arpkit-detai ... ordID=1581 |
Author: | hyper_pak [ Mon Feb 12, 2024 11:22 am ] |
Post subject: | Re: Requesting Help: Choosing Flywheel Bolts |
Yes those are the right bolts. I run a tap into the crank flange to make sure there are no boogers. I also locktite the bolts and torque them. Clutch and pressure plate really don't matter for fitment. |
Author: | volaredon [ Mon Feb 12, 2024 11:26 am ] |
"call center Force? That makes no sense. The bolts that hold the flywheel to the crank aren't the ones that hold the pressure plate to the flywheel. How would center Force know? |
Author: | justa170 [ Mon Feb 12, 2024 12:48 pm ] |
Attachment: Ugh. Sorry, gents. I had my terminology wrong. ![]() It makes sense that the crank-to-flywheel bolts don't care what pressure plate you're using; I'm actually looking for pressure plate bolts. *slaps forehead* So, uh... any ideas on how one selects those? (Let me see if I can fix the title of the thread...) |
Author: | Dart270 [ Tue Feb 13, 2024 5:35 am ] |
Post subject: | Re: I meant pressure plate bolts! Oof. [Requesting Help: Choosing Flywheel Bolts] |
They are 5/16" coarse thread. Get high strength bolts and torque them well (+5 ft-lbs over spec at least) and use loctite. I get 12 pt heads for wrench clearance, and/or if you use a 10" (scalloped bolt holes) PP. Here's what I bought last time, and now I have a lifetime supply: https://www.mcmaster.com/91271A585/ I even put washers under the bolt head, then a washer on the backside and a grade 8 nut. I don't recall the exact length, but 1.25" sounds right. You could also get them longer and cut them to length. Lou |
Author: | Greg Ondayko [ Tue Feb 13, 2024 5:53 am ] |
Dart270 wrote: I even put washers under the bolt head, then a washer on the backside and a grade 8 nut. I don't recall the exact length, but 1.25" sounds right. You could also get them longer and cut them to length. Lou Ooh, Good idea! I have a few boogered holes on the AL Flywheel from over zealous tightening. That is a good solution. Thanks, Lou. |
Author: | Dart270 [ Tue Feb 13, 2024 11:07 am ] |
Yes, I used those bolts originally on the Al flywheel on the 64 Dart. I have a bunch of spares if you want some! Lou |
Author: | Greg Ondayko [ Tue Feb 13, 2024 11:28 am ] |
Dart270 wrote: Yes, I used those bolts originally on the Al flywheel on the 64 Dart. I have a bunch of spares if you want some! Lou Yeah maybe, I dont want to reduce your lifetime supply! I think I have been going through and drill / helicoiling mine, but the clutch and things have been in/ out so many times on the '64 that they are starting to get a bit tired and stressed already. Greg |
Author: | justa170 [ Wed Feb 14, 2024 8:39 am ] |
Dart270 wrote: They are 5/16" coarse thread[...] Here's what I bought last time, and now I have a lifetime supply: https://www.mcmaster.com/91271A585/ Thanks! You just use flat washers, right? (Some ARP kits come with chamfered washers, but it looks like your McMaster bolts don't have a shoulder.)
I even put washers under the bolt head, then a washer on the backside and a grade 8 nut[...] Lou |
Author: | Dart270 [ Wed Feb 14, 2024 10:28 am ] |
Flat grade 8 hardware store washers. Put the smooth side (of the stamping) toward the bolt head. Lou |
Author: | justa170 [ Mon Feb 26, 2024 7:30 pm ] |
Dart270 wrote: Flat grade 8 hardware store washers. Put the smooth side (of the stamping) toward the bolt head. I've received the bolts! Those, along with matching Grade 8 nuts and washers, should be in my machinist's hands tomorrow afternoon. Thanks a million, Lou.
Lou |
Author: | Dart270 [ Tue Feb 27, 2024 3:47 am ] |
Glad to hear it. Enjoy! Lou |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
