It is currently Sun Apr 28, 2024 2:17 am
PostPosted: Thu Mar 28, 2024 7:45 am
Car Model: Dodge Coronet 440
I am sorry for this simple question but I'd like a definitive answer before I try to open my radiator's petcock. I have not drained this radiator before. It's a 1966 Coronet Slant Six with the stock 22" radiator. I just can't see which direction the threads are leaning with my bifocal lenses and OLD eyes! The petcock is more than finger tight and I want to go the right direction to open it before I apply a little more pressure on it. The radiator and petcock are in good looking shape. Thank for the help.
Jon
PostPosted: Thu Mar 28, 2024 8:34 am
If you lean over the rad, push the right side arm on the petcock down.
PostPosted: Thu Mar 28, 2024 10:16 am
So, that would be counter-clockwise if I was under the car looking straight at the petcock? Thank you! I need someone who knows.
PostPosted: Thu Mar 28, 2024 10:38 am
Correct. righty/tighty, lefty/ loosey
66 Valiant Signet 225 nitrous
PostPosted: Thu Mar 28, 2024 11:08 am
Just like loosening a bolt. Note that the threads are LH, so it will actually screw into the radiator even though you are turning it counterclockwise (as viewed from aft of the radiator).
Home of Slant6-powered fun machines
PostPosted: Thu Mar 28, 2024 5:57 pm
Thanks folks. I would have guessed LH thread but it's been so long since I've done this I wanted to check. I'm replacing coolant, thermostat, and thermostat housing drilled for secondary temp gauge.
PostPosted: Fri Mar 29, 2024 11:47 am
All went well today draining and filling the cooling system. The petcock just took a bit more finger nudging in the right direction and it worked perfectly. Thanks again.
PostPosted: Fri Mar 29, 2024 11:54 am
Super. Congrats!
Users browsing this forum: Bing [Bot], Google [Bot] and 29 guests
