It is currently Mon May 13, 2024 1:15 pm
PostPosted: Wed Apr 15, 2020 8:43 am
Car Model: dodge ram W150
Hello I have an 86 dodge w150 with a slant 6 4 speed I bought a doner 85 d100? Or d150 with the same engine will the bellhousing off of the 86 fit the 85 ?
PostPosted: Wed Apr 15, 2020 4:55 pm
The bellhousing is dependent upon the transmission used. If the 4x4 has the big transmission with the shifter in the top cover and the RWD truck has the smaller trans with the shifter on the side then they will use different bellhousings. If the RWD truck has the same trans as the 4x4 then the bell should also be the same.
PostPosted: Wed Apr 15, 2020 5:26 pm
Well !$#@ I thought I could use my bellhousing off my 86.... What product do I need to get to make it work correctly?
PostPosted: Wed Apr 15, 2020 7:18 pm
I don't know what you're trying to do so let's start there.
PostPosted: Thu Apr 16, 2020 5:33 am
Just trying to get my 86 going again by putting the engine from the 85 2wd into my 86 just having complications with the bellhousing at the moment.
PostPosted: Thu Apr 16, 2020 8:53 am
The engine will interchange fine. If the RWD truck has the A833OD and the 4x4 an NP435 you will not be able to swap any of the flywheel, clutch or bellhousing. You haven't said what transmission is in each truck so I've said about all I can.
PostPosted: Thu Apr 16, 2020 1:24 pm
Yeah I dunno what it is either. Thanks man
PostPosted: Thu Apr 16, 2020 4:59 pm
Is the shifter up through the middle of the floor and 3 feet long? Or does it come up along the left side of the hump and is 2 feet long? With chrome handle.
Users browsing this forum: No registered users and 28 guests
