It is currently Wed Apr 24, 2024 6:40 pm
 Post subject: k-frame swap
PostPosted: Sun Feb 14, 2021 10:18 am
Looking at K-frame interchangeability between different generations of a-body.
Specifically looking at using a 74 spool mount in a 63. Is it possible?
 Post subject: Re: k-frame swap
PostPosted: Sun Feb 14, 2021 10:52 am
Negative. It's too wide. A board member near Spokane once attempted to narrow a spool K-member for his early A-body, but threw in the towel AFAIK.
PostPosted: Sun Feb 14, 2021 11:10 am
Two main groups of interchangeability: 60-66, 67-76, if I remember correctly.
PostPosted: Sun Feb 14, 2021 1:49 pm
Okey Dokey.
Thanks for the feedback Reed!
PostPosted: Sat May 15, 2021 7:54 am
Ceej wrote:
Okey Dokey.
I did a bunch of measuring a few years back, the basics are '67 and up chassis are about 2.5" wider, moving steering gear and t-bars, LCA/entire suspension out 1.25" each side. The engine mounting in relation to the frt suspension shifts the eng./trans back about 1.75"-1.875" compared to early-A's. These are the primary reason most headers fail to fit, but I heated, beated, & hammer welded/folded an older 6-1 MP/JR-Heddman to fit My '64 GT. It survived, but it ain't pretty, & that's with the manual box.
If You want spools, & I don't blame You, best to get the mt./brackets & make Your own frame brackets/braces.
cron
