Slant Six Forum https://www.slantsix.org/forum/ |
Fuel Pump Problem and Options https://www.slantsix.org/forum/viewtopic.php?f=44&t=67157 |
Author: | 64 Convert [ Fri Mar 24, 2023 5:56 pm ] |
Post subject: | Fuel Pump Problem and Options |
The last few times I drove my '64 Valiant 225, the oil pressure light flckered at idle when warm. With less than 10k on the engine, I ruled out engine wear, so my first guess was a bad sender. However, when I looked under the car, I saw a few drips from the fuel pump area. Since there was an unusual buildup of oil in the drip pan, I checked the dipstick and found the engine was overfilled about two quarts. I fear that my fuel pump has been pumping gas into the crankcase, and I now have some drastically diluted oil! I only found one Carter pump on RockAuto, so I'm guessing my choice is down to one, and I suppose it is made in China. Does anyone make a high-quality mechanical pump, or should I be considering an electric pump? If so, any suggestions? Comments? |
Author: | SlantSixDan [ Sat Mar 25, 2023 4:20 pm ] |
Post subject: | Re: Fuel Pump Problem and Options |
Get one of these—the kind with the round stamped-steel "hat", like this: Attachment: Also, It will also be a good idea to service the oil pressure relief valve to make sure it's doing its job, as described in these two threads: thread 1, thread 2. |
Author: | Rick Covalt [ Sat Mar 25, 2023 4:57 pm ] |
Hey Dan, thanks for the info! ![]() ![]() |
Author: | SlantSixDan [ Sat Mar 25, 2023 5:03 pm ] |
I never had to re-replace one after installing it, even after pulling it out of a well-worn old box, even well into the gasohol era. It's possible you could have an early failure, but early failure is practically guaranteed with today's Chinese lumps of fuel pump-shaped garbage. |
Author: | 64 Convert [ Sun Mar 26, 2023 4:09 am ] |
Thanks for your help again, Dan. I ordered one and it's on the way. |
Author: | Greg Ondayko [ Sun Mar 26, 2023 12:57 pm ] |
Pump shaped garbage ![]() ![]() ![]() I love it.!! |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
