It is currently Sat Aug 15, 2026 5:57 pm
PostPosted: Fri Apr 13, 2007 9:11 pm
my car makes a wierd noise when the engine is on , it's like a tuk tuk tuk tuk tuk very fast and i'm new on the slant 6 engine so i need help, i just got the car, ... and i love it, and i love the slant six ..!!
valiant volare 78'..!!
PostPosted: Sat Apr 14, 2007 3:10 am
Have you adjusted the valve lash yet? That could very well be the source of your noise.
It's an easy job, using basic tools, and you'll get to replace that leaking valve cover gasket at the same time.
-Mac
PostPosted: Sat Apr 14, 2007 5:18 am
Contributor
Cracked exhaust manifold?
PostPosted: Sat Apr 14, 2007 5:26 am
Could be a bad bearing, piston slap, wrist pin, loose torque converter/flywheel. Need more info, like where the sound comes from, does it change intensity/speed whith a change of RPM/load?
PostPosted: Sat Apr 14, 2007 6:27 am
Better yet... can you post a link to a sound file?
Let's hear it!
:D
-Mac
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
