It is currently Thu May 07, 2026 9:32 am
PostPosted: Mon Apr 30, 2007 7:24 am
How to tighten the antenna base?
I looked under the fender on my 65 and the square peg just spins loosely...no luck tightening from the top where there are 2 indentations on the top of the chrome round part.
thanks!
PostPosted: Tue May 08, 2007 7:58 am
100 views and no one else can help?
PostPosted: Tue May 08, 2007 1:32 pm
Have you tried to remove the round chrome part on top?
I figure it might be a kind of cover/locknut, covering a second nut?
Just an idea, I dunno...
 Post subject: tighten
PostPosted: Wed May 09, 2007 2:31 pm
There are many diffrent setups. most factory units used a special tool.others a nut with spacers and adapters maybe something is missing. you should be able to tighten by hand to snug if all parts are there........
from the top side of the fender , under the fender just butts against it.
PostPosted: Wed May 09, 2007 5:34 pm
If it's a factory antenna, the plate under the fender should engage a notch to keep it from turning then the bezel threads on to clamp the mount to the fender. If the bezel is the type with a circle of notches around it there is a tool made for the purpose but in a pinch you can use a pair of long nose pliers. That runs the risk of slipping and possibly scratching the paint or marring the bezel. Better to use the tool.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun May 13, 2007 6:28 am
thanks for the help everyone..ill get under the fender and take a
look again!
Users browsing this forum: Bing [Bot] and 0 guests
