It is currently Wed May 20, 2026 8:07 am
 Post subject: Finding a Carter BBD
PostPosted: Wed Aug 25, 2010 9:21 pm
I'm planning to hit the junkyards tomorrow to find a Carter BBD (and hopefully the rest of a super six setup). Can anybody tell me which cars to be looking for so I don't pop the hood on every mopar in the yard?
Also, if anybody knows a good (preferably inexpensive) source for NOS BBDs it would be much appreciated.
'66 Dodge Dart
PostPosted: Thu Aug 26, 2010 1:30 pm
76 Volare's/Aspens, trucks on up.
PostPosted: Thu Aug 26, 2010 1:33 pm
if ur looking for the super six setup... 75 and up (75 was the first year they started the super six)
74 plymouth duster, 225 single barrel slant six
PostPosted: Thu Aug 26, 2010 1:51 pm
All(non california) 76-79 Volare and Aspen wagons had BBD's
Lots of 318 cars had them as well, and a 318 BBD will work on a slant
PostPosted: Sun Aug 29, 2010 5:32 pm
Thanks everybody, I didn't end up finding anything in the way of a Super Six. However I did find a nice 67-74 style head :D Snatched it out of a early '70s Dart Custom. I'll keep looking.
Any tips on identifying pricy problems on a BBD while still on the vehicle?
Also tips on getting those two bottom center bolts on/off of the intake and exhaust manifolds? I couldn't figure out a good way to remove these so I ended up removing the head first and flipping it to be able to access the bolts.
'66 Dodge Dart
PostPosted: Sun Aug 29, 2010 5:57 pm
You need a long extention, I have found a 1/4" drive 10" extention and a shallow socket works really well (a deep well socket hits the heat riser). I've have removed enough intake and exhaust combos I can get those two pesky nuts quickly by feel. The difficult part is getting them and the triangle washers back on for reasembly.
PostPosted: Fri Sep 03, 2010 9:29 pm
I just did this swap and had a great idea for getting the washers on under the intake/exhaust:
Get a magnetic pick-up tool, put the washer's hole on the end of the magnet and put it over the bolt, once it is on the bolt gently slide the magnet tool to the side of the washer exposing the bolt and push it on.
Worked like a charm. ;)
1965 D100 225 slant 6, NP435 Utiline.
PostPosted: Sat Sep 04, 2010 7:03 am
Another second for a 2-bbl from a 318. I'm running one on my 170 and it has been working fine for a few years. As others will say, it was a very good upgrade - it was much quicker for me right away.
PostPosted: Sat Sep 04, 2010 11:13 am
Thanks everybody.
Regarding the 318 BBDs, I've heard they are slightly different than the BBDs on slants. Is this true and do they look different or function differently?
'66 Dodge Dart
PostPosted: Sat Sep 04, 2010 6:30 pm
/6 BBD's had a 1 1/16 bore, 318's had a 1 3/16 bore. 78 and up 318's (with lean burn?) used the small bore carb. I used an early 70's BBD with a wood spacer on my aluminum "super six" intake, with a larger exhaust. 'twas fun.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 8 guests
