It is currently Fri Jan 02, 2026 2:09 pm
 Post subject: turbo feedline question
PostPosted: Sat Sep 04, 2010 10:56 pm
Ok so i am still planning and squirreling parts away for my turbo build for my slant, and so far everything i have read about 4 banger imports running my holset HX-35W turbo say you need to run a -4AN feed line from the op, and need to run a restrictor, and as per the service manual Holset's tend to blow out oil seal at 70+psi, but since slants never reach that is a restrictor still required ??
or does the -4AN feedline increase oil pressure going to the turbo ???
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sun Sep 05, 2010 6:02 am
-4 does not increase pressure to the turbo. You should be fine. My first turbo was a journal based turbo and did not run a restrictor. My current turbo was supplied with a restrictor.
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Sep 05, 2010 6:05 am
awesome appreciate it Shaker !!
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 17 guests
