It is currently Wed Jun 03, 2026 12:30 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Sun Mar 20, 2011 2:34 pm
Well Guys,
The clatter is still there after replacing the rocker arm assembly and push rod on old #6 exhaust valve. I can get get the clatter to go away by adjusting down to .004in. I also had a valve job done just prior so I'm thinking maybe it's a sticking lifter or even the cam lobe is worn.
Does anyone have any ideas?
Ken
65 Dart Convertible Super Sixed
PostPosted: Sun Mar 20, 2011 3:16 pm
a well oiled adjusted slant will clatter just like a sewing machine .010 intake and .020 exhast any tighter will burn valves
PostPosted: Sun Mar 20, 2011 3:58 pm
Okay, So I set it back to .020. What is still causing the very loud clatter from #6?
Ken
PostPosted: Sun Mar 20, 2011 4:18 pm
That has not been my experience. Image
PostPosted: Tue Mar 22, 2011 5:16 pm
Well, I did a compression test today. Cold, They all above 150 lbs. Hot was well over 155. All of the cylinders were pretty much equal=/- a pound or two. I checked all the push rods for straightness. I found two that were questionable and changed them out. I advanced the timing to 5* above tdc and the engine sounds very healthy when reeved up and it idols smooth. I left #6E at .020 and thought I would drive it a little and hope that #6 gets better. If not, the only thing left is the cam and lifters.
Ken
