It is currently Tue Jun 23, 2026 5:57 am
 Post subject: Trunk mount battery?????
PostPosted: Sat Aug 14, 2004 9:33 pm
When a battery is installed in the trunk ,should the cable be run through the inside of the car or along the bottom???
HyperValiant
PostPosted: Sat Aug 14, 2004 11:08 pm
If its just a single wire, inside. Otherwise the weather will eventually make it brittle and it will corrode easier. I would never run power wire outside unless it was some sort of SO or similar cord.
When I mounted my electric fuel pump on the frame rail just past the rear end, I used 2 conductor SO cord. SO cord has fibers between the individual conductors and an outer shield that is chemical and weather resistant, but such a cord is not suited for a main battery feed because it is not availible in a heavy enough gauge and in single conductors.
PostPosted: Sun Aug 15, 2004 8:27 pm
If you run the cables under the car, I would recommend doing it through some kind of conduit...like plastic pipe held on with brackets or something. I'll let you know when I do it. :wink:
'68 Dodge Dart 4dr Sedan
PostPosted: Sun Aug 15, 2004 9:03 pm
At your hardware store, in the electrical section you can find some flexible metal conduit that they use for commercial wiring. That would work well, you wouldn't need a bender or any special tools to use it.
Easy to work with, you don't need a hacksaw to cut it
PostPosted: Wed Aug 18, 2004 6:14 pm
I run the ground stap to the frame then ran the battery cable up the inside of the channel and attached it with those rubber coated cable mounts.
