| Slant Six Forum https://www.slantsix.org/forum/ |
| Webbers & Intakes https://www.slantsix.org/forum/viewtopic.php?t=10293 |
Page 2 of 2 |
| Author: | 225_6th_Street [ Fri Sep 24, 2004 10:46 am ] |
For a plenum the Weber to SU adapter will work perfectly. Each pair if cylinders and pair of barrels has a common area between the Venturis and the runners with the downdraft 2 bbl adapters stuck to the SU flange. And if you look at the SU intake there's a balance tube between the three Plenums. |
| Author: | mnecaise [ Fri Sep 24, 2004 11:03 am ] |
A DFAV has the same baseplate as the DGV. It's just got the throttle linkage on the other side. |
| Page 2 of 2 | All times are UTC-08:00 |
