| Slant Six Forum https://www.slantsix.org/forum/ |
| heat control valve https://www.slantsix.org/forum/viewtopic.php?t=20836 |
Page 2 of 2 |
| Author: | Doc [ Mon Nov 27, 2006 9:50 am ] |
Quote: I am curious as to whether I should leave the counterweight against the stop pin for the time being or not. Would this leave it open or closed?
Against the stop is the "full heat" (closed) position.I would rotate it counter-clockwise and leave it in the "open" position for now. DD |
| Author: | AnotherSix [ Tue Nov 28, 2006 8:22 pm ] |
The WD stands for "water displacement" and the 40 is because it is (was?) formula #40 during development. And that remains it's best application, great to have around a boat and boat motors. My grandfather was using this stuff in aerospace at the Skunkworks before it was available to the public. Among other things I have used it as a starting fluid for high compression two strokes, it doesn't do damage like ether will. And what about torching Black Widows around the garage? In any event if the factory makes a part or chemical and you can still get it then I would think thats as good as it's going to get. I have used a CRC high temp lubricant spray on wastegates that would probably work real well too. It has a penetrating solvent carrier and leaves behind graphite and molibdinum sulfide for the lubricant, good for about 1400 F. It's expensive and hard to find, an industrial supply type of item. |
| Page 2 of 2 | All times are UTC-08:00 |
