It is currently Tue May 26, 2026 8:24 pm
Post new topic  Reply to topic  [ 60 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Take another look
PostPosted: Mon Feb 19, 2007 6:44 am
Take another look and see what you think. I have revised the collector and it is a lot smoother. I also raised the turbo angle for a tighter clearance. I still need to intergrate the wastegate. Working with 304 stainless is a pain in the neck.
Just looked at the pics and it does look smoother. Like I said (and cmexlr8 said), I'm not sure if it matters but couldn't hurt.
Thanks Charrlie for the pic, I would have never thought it would clear the hood. Then again a sidedraft never crossed my mind either. :lol:
Chris'
Autobody
Restoration
Service
PostPosted: Mon Feb 19, 2007 9:40 am
With the webber carb it did clear the hood. That carb did not work well, though. Had a bad bog at low speed wot condidtion. Could not get enough pump shot. I wound up with a 500 Holley 2bbl on a 90 degree adapter, which worked well. However I did have to use a hood scoop and put the air cleaner up in the scoop.
 Post subject: It Fits
PostPosted: Mon Feb 19, 2007 2:39 pm
The header fits like a glove. I will be posting some pics later.
PostPosted: Mon Feb 19, 2007 6:05 pm
The header fits good. There may be some clearance issues if somone has milled the heads alot. The only place it may hit is the adjusting nut on the steering box. I am sure that can worked out.
PostPosted: Mon Feb 19, 2007 6:46 pm
SSRN National Champion
Looks great James thats what grinders or for. Starting to get the parts together, i want all componts in hand then build our turbo engine. Thanks Ron Parker :D
It Aint Over Until I Win
 Post subject: Personal Record
PostPosted: Mon Feb 19, 2007 7:43 pm
Hey Ron, I would love to see you run your best ever this year and set your best personal record.
 Post subject: Runners
PostPosted: Wed Feb 21, 2007 6:12 pm
I will be working on your runners tomorrow Ron.
PostPosted: Wed Feb 21, 2007 7:07 pm
Sounds good James some of our parts are coming in this weekend and we are bringing this project together. The turbo and compants might not get here until next weak talked to Tom Drake and doing a little more rsearch for a blow thru system. We are going to try to do this right not just throw parts at and say lets go. Yall aint seen nothing yet. :D Thanks Ron Parker :D
Bagels On Juice Im On Boost.
PostPosted: Thu Feb 22, 2007 12:53 am
One thing to look out for guys is the oil drain back for the turbo, the pics are hard to tell what kinda angles & down flow you have. Just check it and make sure it flows good on the oil return, if it dont it will cause smokeing. No turns,kinks, needs to go stright down to oil pan or what ever it goes to.
As far as the header flow, you can put a copper tube in it ( like a oil pressure line tube) and run it to a Map sensor and measure the exhaust pressure. This will greatly effect HP,spool up, level at which detination becomes a problem, how much boost you can run safely and how quick the torgue of the engine falls off if the system builds back pressure.
Although you do see many V8s running log headers, they have so much HP that a loss of HP from things like this is not noticed as much. And the biggest problem they have is blowing head gaskets when they do have compromizes. Ofcourse they can make up for things like this with the tune up,race fuel, but they also (in the cass of something like a LS1) have a lot better combustion chamber to work with. And most are running race fuel from the get go.
As a rule of thumb, you can double the HP with 15 psi of boost on a effeicant engine & turbo setup.
Good Luck with your prodjects, be looking forward to seeing some screaming /6's.
Jess
PostPosted: Thu Feb 22, 2007 3:18 pm
Thanks for that tip Tom already warned me about that but all help is appreciated. Right now unless we change our mind Im looking at a Borg Warner T-4 60-1 fast spooling turbo. A adjustable boost preasure gate and I know what cam profile im going to use. Thanks Ron Parker :D
Bagels In A World Of Trouble
PostPosted: Thu Feb 22, 2007 7:46 pm
Good luck with your turbo build Possum. I am watching closely. I am 100% convinced that a turbo is the best way to build power, but I am still skeptical about a carbureted system for bracket racing. I'd be skeered to get hung out on the tree and leaving at low boost. Make me a believer buddy. :shock:
PostPosted: Fri Feb 23, 2007 8:40 am
Well Bagel thats why im trying to just not get parts and buil this engine we are doing a lot of research and trying to build a engine for this project
Question for you 2.2 turbo pistons 1mm over where does that take you on the engine bore. Thanks Possum
Bagels on Juice Im On Boost
PostPosted: Fri Feb 23, 2007 8:41 am
PostPosted: Fri Feb 23, 2007 6:56 pm
Ron, IIRC that would be +.090". Std 2.2 is +.040", my .5mm over is at +.065". :shock:
PostPosted: Fri Feb 23, 2007 6:58 pm
Free post :shock:
