The 1A Auto exhaust manifold close-up
https://www.slantsix.org/forum/viewtopic.php?t=22614
Page 2 of 2
Author:  75 slanted swinger [ Tue Apr 10, 2007 4:58 am ]
Earlier in this post I asked if the manifold was for a "super six" 2bbl or 1bbl - to clarify - is the manifold to exhaust pipe connection larger in diameter for the 2bbl ? Or is the diameter the same for both the 1bbl and 2bbl manifolds ?
thanks jeff
Author:  SlantSixDan [ Tue Apr 10, 2007 7:01 am ]
Same. There is no difference between the exhaust manifolds used with 1bbl and with 2bbl setups.
Author:  Matt Cramer [ Tue Apr 10, 2007 12:17 pm ]
And if you are wondering about this manifold, the exhaust pipe ID is 2" at the flange. I just measured it today.
Author:  75 slanted swinger [ Wed Apr 11, 2007 5:40 am ]
Thanks :!:
Author:  Cuda69 [ Wed Apr 11, 2007 4:30 pm ]
Post subject:  A-1 Exhaust Manifold
I also purchased a "A-1" exhaust manifold. The casting was very poor and actually had sand holes in the casting below the heat riser. I repaired it with J B Weld prior to installation and it's been fine so far. It also had the "China" name cast in to it. If I had it to do again, I would buy one from a junk yard !!!
Page 2 of 2 All times are UTC-08:00
