| Slant Six Forum https://www.slantsix.org/forum/ |
| what's the limit https://www.slantsix.org/forum/viewtopic.php?t=31718 |
Page 2 of 2 |
| Author: | turboram [ Wed Oct 22, 2008 5:09 am ] |
Does anyone have a bronse oil pump gear like the v8s use in high performance applications? v8s have the same problem untill they switch |
| Author: | Charrlie_S [ Wed Oct 22, 2008 6:20 am ] |
If I'm not mistaken, the V-8's only use the bronze gear, if they are running a steel roller cam. |
| Author: | Doc [ Wed Oct 22, 2008 11:53 am ] |
I have case hardened SL6 oil pump gears and gears made from a special nickel - bronze alloy. As noted, the bronze gear is designed to be used with steel cams. DD |
| Page 2 of 2 | All times are UTC-08:00 |
