| Slant Six Forum https://www.slantsix.org/forum/ |
| Let the grinding begin. Cut Aussie intake. https://www.slantsix.org/forum/viewtopic.php?t=35504 |
Page 2 of 2 |
| Author: | mopardemon71 [ Wed May 27, 2009 8:18 am ] |
Do you think that they made the top thicker to support the manifold? It would seem that it would crack from top to bottom. On another note to highjack this tread I nominate Shaker223 for "slant enthusiast of the year" |
| Author: | Shaker223 [ Wed May 27, 2009 9:06 am ] |
It may have been core shift, I really don't know. If it is an issue, I'll weld some stiffening runners on the bottom. Doc might be better able to answer the casting type of questions. |
| Author: | MichaelS [ Wed May 27, 2009 5:28 pm ] |
Would extrude honing have worked on this without having to cut it open? |
| Author: | Shaker223 [ Wed May 27, 2009 6:19 pm ] |
Quote: Would extrude honing have worked on this without having to cut it open?
Yes but it is over $300. Additionally, I would think it removes the same amount of material from all sides. In my case, the floor is fine where it is at and there is more material that needs to be removed from one side.
| Author: | Shaker223 [ Thu Jun 11, 2009 11:51 am ] |
3 runners matched to the port in the head. 3 to go. CC's of water Port**Before****After****Difference****% Volume Gain 1*****257******322*********65********25.29% 2*****250******311*********61********24.40% 3*****244******294*********50********20.49% |
| Author: | mopardemon71 [ Thu Jul 02, 2009 10:25 pm ] |
in speaking today with PP&R the extra material is for support due to length of the intake. It is to help the "mounting ears" and runners from pulling/sagging. |
| Author: | Shaker223 [ Fri Jul 03, 2009 5:29 am ] |
If it becomes an issue, I can build an external support or add extra material on the bottom (externally). |
| Author: | AussieSpeed [ Tue Jul 07, 2009 7:39 am ] |
Quote: in speaking today with PP&R the extra material is for support due to length of the intake. It is to help the "mounting ears" and runners from pulling/sagging.
Well well you are 1 switched on guy, ok now that you have cut the manifold open i will fill in a few blanks, These manifolds were designed to be used on a street/ strip type engine. from feedback i received they are also performing great on race engines. This manifold took me a long time to develop so it was true horsepower out of the box. The casting is thicker at the top for strength, If you look at the flow figures they are staggered for a reason & i am glad now ported that they are all still staggered as there is a reason for this. by increasing the port volume by porting it it will drop of a bit of air speed & i dont recommend it for a hot street car as it all comes down to air speed & torque. in a forced induction engine it is a totally different thing.. For those who think we are holding back or are not continuing the AussieSpeed PP&R blower manifold for the slant it is not the case, If you run a carb on top of your blower fuel distribution is more critical than a N/A engine... beacause if you get 2 out of 6 that are getting less than the others there is a very good chance it will go BANG.. detonation is a wonderful thing.. So good luck with ya projects & the SL6 AussieSpeed PP&R blower manifold is only weeks away..Regards Mark... |
| Author: | Shaker223 [ Tue Jul 07, 2009 8:27 am ] |
This will be for a boosted application so, like you said everything is different vs a NA application. Thanks for a great product! |
| Page 2 of 2 | All times are UTC-07:00 |
