Tips for pulling rear gears at the boneyard?
https://www.slantsix.org/forum/viewtopic.php?t=37540
Page 2 of 2
Author:  volaredon [ Sun Oct 18, 2009 6:42 pm ]
They used BOTH an 8-1/4 (just like what we are all used to) OR teh Dana 35 in Cherokees; but again you need 97-older to get the correct splines. I dont believe they ever used an 8-1/4 as a front diff; so that one is moot; but if so as already was mentioned, if they had the gears would be reverse cut.
Author:  Bren67Cuda904 [ Tue Oct 20, 2009 4:20 am ]
Before taking apart yard rear (at home) measure backlash. It should help you with setup to get the used gears to run quite.
Page 2 of 2 All times are UTC-07:00
