| Slant Six Forum https://www.slantsix.org/forum/ |
| JP timing set questions(cam degree results are in) https://www.slantsix.org/forum/viewtopic.php?t=46180 |
Page 2 of 3 |
| Author: | Jeb [ Wed Sep 07, 2011 5:36 pm ] |
All the spark plugs are already out and the piston stop is in #1. Also removed all the pushrods from cylinders 2-6. It's still a PITA to turn over and seems to get "stuck" for no reason. That crank sprocket is super tight. I'm afraid it's going to break as I'm pulling it off. Any suggestions? |
| Author: | 805moparkid [ Wed Sep 07, 2011 8:31 pm ] |
measure the crank snout to .0005 clearance... then take the sprocket to a machine shop and have them hone it to that spec... |
| Author: | Jeb [ Thu Sep 08, 2011 10:29 am ] |
Well after trying for 3 hours this morning and shearing a grade 8 bolt in my puller, the crank gear hasn't budged. Looks like it's forever stuck at 2* advance. Any suggestions on degreeing this thing with it advanced already? I know I'm going to have to use offset bushings in the cam sprocket if I want any changes. |
| Author: | USAJon [ Thu Sep 08, 2011 11:19 am ] |
I would fix any issues have first..crank bolt etc.. |
| Author: | Jeb [ Thu Sep 08, 2011 11:42 am ] |
I don't have any other issues besides trying to get this cam degreed. |
| Author: | 805moparkid [ Thu Sep 08, 2011 12:25 pm ] |
Quote: I would fix any issues have first..crank bolt etc..
exactly... get the bolt out...did you ever finish degreeing it to see where the cam is actually at? you might be able to put heat to the sprocket... did you lube the snout? |
| Author: | Jeb [ Thu Sep 08, 2011 12:36 pm ] |
The bolt is out, it's been out. I tried the heat thing using a bottle torch and map gas. That's when it sheered off one of the arm bolts on the puller. I lubed the snout with engine assembly lube when I put it on. It will not budge ANY from it's installed position. No I haven't gotten it degreed yet, still waiting on my dial indicator to arrive from summit. Also ordered 1 mechanical lifter to use for degreeing purposes. I did get my degree wheel and crankshaft socket this afternoon. Used the wheel and a piston stop to find absolute TDC. Got the engine sitting there until the dial indicator arrives. That crankshaft socket was well worth the money. Beats the hell out of the bolt, nuts, washers technique.
| Author: | 805moparkid [ Thu Sep 08, 2011 5:37 pm ] |
so how much effort did you use to get it one? the sprocket |
| Author: | USAJon [ Thu Sep 08, 2011 5:42 pm ] |
Quote: Quote: I would fix any issues have first..crank bolt etc..
exactly... get the bolt out...did you ever finish degreeing it to see where the cam is actually at? you might be able to put heat to the sprocket... did you lube the snout? it is needed. |
| Author: | 805moparkid [ Thu Sep 08, 2011 11:33 pm ] |
you mean of degreeing a cam? |
| Author: | Slanted Opinion [ Fri Sep 09, 2011 2:59 am ] |
Yes, I'd love to see a you-tube of timing chain replacement / degreeing cam on a slant six. Once you solve your issues, you could repeat the process in probably a matter of minutes... would make for a great video to link from the "How To" section on this board. - Mac |
| Author: | Jeb [ Fri Sep 09, 2011 7:29 am ] |
Quote: so how much effort did you use to get it one? the sprocket
Didn't use hardly any effort at all, I heated it up and slid it on.
| Author: | 805moparkid [ Fri Sep 09, 2011 7:54 am ] |
if i had a motor sitting on a stand i would.... |
| Author: | Jeb [ Fri Sep 09, 2011 7:58 am ] |
After I get this motor successfully degreed I will run back through the steps on a video. |
| Author: | 805moparkid [ Fri Sep 09, 2011 12:21 pm ] |
Quote: Quote: so how much effort did you use to get it on? the sprocket
Didn't use hardly any effort at all, I heated it up and slid it on.or call jp for a bottom sprocket, cut the old one off... which is what i would do... then do as i said above and have the sprocket honed to the correct ID.. also above you said it gets stuck... did you rebuild the engine? is the flex plate on it? |
| Page 2 of 3 | All times are UTC-07:00 |
