| Slant Six Forum https://www.slantsix.org/forum/ |
| Best Cap And Rotor https://www.slantsix.org/forum/viewtopic.php?t=47544 |
Page 2 of 2 |
| Author: | Danarchy [ Wed Jan 11, 2012 8:16 pm ] |
This is what I got from NAPA,same size and design as the tan colored one I replaced,but the tip is some other metal(not brass) ![]() time will tell on wear. |
| Author: | raPoM [ Wed Jan 11, 2012 8:21 pm ] |
No problem bud,thanks for the leg work on the cap. I got my cap and rotor on order too! |
| Author: | 805moparkid [ Wed Jan 11, 2012 10:01 pm ] |
Quote: No problem bud,thanks for the leg work on the cap. I got my cap and rotor on order too!
no worries... you gave he info so i had to do something!
| Author: | raPoM [ Wed Jan 11, 2012 10:20 pm ] |
Quote: Quote: No problem bud,thanks for the leg work on the cap. I got my cap and rotor on order too!
no worries... you gave he info so i had to do something! |
| Author: | 805moparkid [ Wed Jan 18, 2012 5:01 pm ] |
ok i got my new rotor and cap.. the ca is fine, blue streak with brass contacts... but the rotor looks to be the same as my duralast junk... i got the MO-3000 extended and looks no different... did i get the wrong one? |
| Author: | raPoM [ Wed Jan 18, 2012 5:15 pm ] |
Is it tan? It must be tan,and the tip will be noticeably longer when compared to the standard rotor tip. |
| Author: | 805moparkid [ Wed Jan 18, 2012 5:16 pm ] |
Quote: Is it tan? It must be tan,and the tip will be noticeably longer when compared to the standard rotor tip.
yes it is tan... and next to a durulast its exactly the same...
| Page 2 of 2 | All times are UTC-08:00 |
