It is currently Sun Nov 08, 2026 1:23 am
PostPosted: Wed Jan 22, 2003 8:28 pm
i ran an ignitor kit in my 318 swinger with a msd box and it ran great. without the msd it started and ran no better than properly adjusted points. in fact, the only thing i can say about the ignitor is that there is no need to set and replace points and it was truly a simple swap. long term reliability? i've run the ignitor for about 8 months now with no hassles. i have all the parts to swap in chrysler eis but have been too lazy to do it after fixing everyone else's cars all day.
i do not agree that any electronic setup should be considered without and electronic regulator. they just do a much better job than the point-type system and an ignition pickup needs full power at all times to be effective. it will work, but not that well.
-james
PostPosted: Thu Jan 23, 2003 10:23 am
check your altinator earlyer models have one feild terminal grounded to the case . later ones that were used with the electronic regulator have both terminals isolated Bruce Johnson
78b4ramSnortbed/6
PostPosted: Thu Jan 23, 2003 3:24 pm
Stock drop in replacement regulators from Wells (get them at Autozone) are electronic even for the older one field wire alternators.
Dave Clement
68 Barracuda (Hot-Rod \6)
http://mysite.verizon.net/vze4pgxf/
